Willwork4truck
Ouch, 1270#... E Torque must add a lot since we both have Ltd's, and I have 4x.
The battery alone is 30lbs, then you have the motor/generator and controls systems. in total its about 100lbs for that.Ouch, 1270#... E Torque must add a lot since we both have Ltd's, and I have 4x.
I don't think the E Torque is what is giving him the low rating. My Rebel has the E Torque and I have 1527 LB available.Ouch, 1270#... E Torque must add a lot since we both have Ltd's, and I have 4x.
E Torque and all the options are heavierI don't think the E Torque is what is giving him the low rating. My Rebel has the E Torque and I have 1527 LB available.
We both have ltd’s, I dont have the advanced safety group but where’s the difference other than ET?I don't think the E Torque is what is giving him the low rating. My Rebel has the E Torque and I have 1527 LB available.
Here is my load sticker take a look at the truck description you will sse a great differenceWe both have ltd’s, I dont have the advanced safety group but where’s the difference other than ET?
You will want to go to our sister site www.hdrams.com and check out the payload thread there. This one is for RAM 1500Hey all. Anyone has the payload info for a recent 2500 Limited trim and well optioned. Trying to see how far down from the published 2900 in RAM's brochure I'd end up. Any thoughts? Thanks folks. NP
Cummins equipped trucks can quite easily get under 2k.Hey all. Anyone has the payload info for a recent 2500 Limited trim and well optioned. Trying to see how far down from the published 2900 in RAM's brochure I'd end up. Any thoughts? Thanks folks. NP
Oh. Sorry. Will do. Thanks.You will want to go to our sister site www.hdrams.com and check out the payload thread there. This one is for RAM 1500
Do you have this spread sheet? I’m trying to calculate my payload because I’m almost positive i won’t have enough for my trailer. And now I’m gonna have to order a 2500 instead.Ok I put together a spreadsheet with all the payload and option info we have on Limited trim/4x4/5'7". Based on the spreadsheet the following numbers work exactly for all the trucks so far (except ryelinek). These are still a work in progress so there will be more refinement.
Here's the weight of the most common options (as near as I can tell till we get more data):
Limited trim - 166lbs
Bed utility group - 25
Level 1 - 86
Advanced safety group - 50
Sunroof - 70
Anti spin - 16
eLocker - 16
3.92 Axle ratio - 0
eTorque - 80
Brake controller - 0 (not full tow package)
Body colored bumpers - 0
22" wheels - 0 (vs 20" standard wheels)
33 gallon fuel tank - 73 (91 if eTorque equipped)
Offroad Group - 119 (minus eLocker)
Ramboxes - 163
To test this, start with the payload listed in the towing chart for the 4x4/Crew Cab/Hemi/5'7" bed configuration (1800lbs). Then subtract the weight of each option to get to the number on your payload sticker.
If you have a Limited/4x4/5’7” and get a different payload number let me know what your payload sticker says and a full list of your factory options and I can try to refine the numbers.
Other option weights (not specific to any trim)
Wheel to wheel side steps - 60
4 corner air suspension - 34
6’4” bed - 50
4x4 - 240 (but you get 200 more GVWR so 40 net reduction in payload)
Based on those options I’d estimate 1350 payload. The spreadsheet won’t give exact number for a Laramie. I did post up the weights of some common options in post #108 of this threadDo you have this spread sheet? I’m trying to calculate my payload because I’m almost positive i won’t have enough for my trailer. And now I’m gonna have to order a 2500 instead. View attachment 82754
