Thank you for the response! I found out using sound pop app that my front right speaker was out of phase. I swapped the wires and it now sounds a bit more normal. All speakers now in the truck are + phase.For the base 6 speaker audio the dash speakers are 8 ohms and the doors are 2 ohms.
The amplified systems (Alpine and HK) are different from the base audio.
I don't know what "not quite right sounding" is but you have several options from least to most expensive:
1. Play around with the EQ to see if you can improve the sound.
2. Adding a resistor. **
3. If the Infinity speakers don't have bass blockers you could add some to see if dropping the lows out of the dash makes a difference.
4. Change out speakers.
** Adding a resistor will help change the load between the dash and front door speakers but you will be effectively adding a 3rd speaker in that loop. Even though the resistor can't play sound it will drop the appropriate amount of voltage for the resistance. You will re-balance the load with the door speaker but you will have a weaker dash speaker now that there's another resistor in the dash circuit.
Those are the basic options until you get into changing the system around to benefit the speakers (amps, bypasses, wiring, etc.) which adds to the price and complexity. I have not done any of that so can't speak to it. Others may chime in with some other solutions.
With the anc module, how would I go to 6 channels? I do not have any resistors installed, would that help anything? Currently I have the system pushed to the back speakers 2 clicks. If I were to add an Amp, what would you suggest? Also maybe a dsp? Ok... so what parts for a 6 channel Amp, display, and any adaptors needed to make it plug and play?? Not looking for subs.
