Rear window surround crack.
SteelCityRags
Ohio
So unfortunately I get to join this illustrious club of cracked rear window liners with the slightest leak starting.
Heading to the dealership today with the pics and star case to see what they’ll do to help
Sent from my iPad using Tapatalk Pro
So just got done with the leak check visit at the dealers and they actually found two leaks. One obviously from the crack and one at the third brake light
They resealed the third brake light and put in the order and warranty approval for the rear window replacement.
Now we play the waiting game on the window and approval
duke2001
So, just curious, has the cracks leaked anymore since the third brake light was re-sealed?
PanhandleRam
Niceville, FL
Just found the cracks today, 2019 1500 Laramie with 42K miles. Has anyone had to replace the rear window after warranty has expired? I had the third brake light leak about 6 months ago and the dealer has already repaired that.
duke2001
So you have the cracks, but are you seeing leaks by the cracks?
Gs72174
I’ve got 60 plus thousand mile on my 2019 and I’m waiting to hear from Ram Cares to see what if anything they can do for me. The dealer said the rear window would be about $1500 before labor. I have cracks on both sides of the rear sliding window and that’s where the water was coming through. I’ve already replaced the gasket on the third brake light and it seemed to have stopped leaking through one of the cracks. If Ram Cares isn’t able to help out, I’ll try a sealer around the rear window.
borden72
Maybe this will help out.
2019-2020 Ram 1500 Backlite Glass 68426398AC | Steve White Parts
securityguy
North Florida
So, I have visible cracks in my frame, but no leaks , why?
What I am saying is that fixing your third brake light will not fix the crack issue with your window frame. Could the water coming in thru the brake light seep thru the rear frame? It is absolutely plausible. However, the cracked frame should still be replaced and still has the potential to leak on its own.
Kienvu14
Well just got my truck back and was told the part number is the same as original, so no new revisions on the windshield. One thing that may be promising this go around is my new rear window doesn’t have the faint crack lines as before. On the factory one i noticed a faint line mark prior to the crack, this one doesn’t. Fingers crossed
borden72
I really appreciate that. Thanks for the heads up!
I'm not sure they ship glass but you may be able to find another wholesale supplier that is close to you. With Steve White, use Face1 for an additional discount.
PanhandleRam
Niceville, FL
The cracks did not appear until about six months after I had the third brake light leak fixed, I'm going to try putting some silicone on the crack through the third brake light for now and see if that stops the leak. I really don't want to pay out of pocket to replace the rear window when it may just leak again.
duke2001
How was the third brake light fixed? Was it replaced by the dealer or did you repair with a new gasket yourself?
NewRam92
Called my dealer today about the window surround crack, talked to the service advisor and he said bring it in, we'll take pictures and get authorization from FCA and bring you back in to do the repair once we get the green light from them. Seems like he's heard of this before and didn't give me any trouble. Fingers crossed!
duke2001
Welp, add me to the list of rear window crack trucks...
Please make sure your third brake light gasket is sealing properly, If you replace the window without checking this gasket, you may still have a leak and not have the cracks to help you identify it.
