What I initially thought was a leak just because of the sunroof drain grommet being installed incorrectly turned out to be a combination of that, the third brake light, and this crack that I found today while doing some more leak testing. You can see where I dropped some Permatex flowable silicone yesterday - I had found another smaller crack over near the left side of the passenger side of glass. I don't know how I missed this yesterday but saw it today and dropped some silicone on it. Going to let it cure and leak test again tomorrow, but I'm hoping this ends my leak saga. I didn't see any cracks on the drivers side frame.
I solved the third brake light leak with the thicker weather stripping that others have bought at Lowe's/HD, but actually just installed a 2021 LED third brake light (the new style one with the camera in it). The seal on it seems quite a bit more stout than the one that came on my 2019, so hoping I don't have to end up replacing that seal too. Guess we'll see.
this is sickning, it should be an obvious recall..
Hello everyone, we are deeply sorry to see what you are experiencing with your vehicles. Our team would certainly like to have a case escalated to offer support in reaching a resolution on your behalf. In order to begin this process of us working alongside your dealers, please send us a private message with your VIN. Thank you,Welp, @RamCares & Board, add me to the list;
I'd seen these cracks and they were so uniform, I thought it was just a 3 piece trim (until I looked closer and saw they're crooked)
I've got more video with water stains on the seats, the carpet under the seats has a damp feel compared to other areas so far, but that's one big rain of the season so far.
This now is in addition to an idling squeal the truck has had for months, I've finally recorded video of the issue and will likely start another thread.
@RamCares , I'll be headed to a dealer here in my zipcode, let me know if you need any info to log this issue. I hope they can handle this as they've not had the best service reviews in the past...
How about using a slightly softer metal for the frame? Something a little less brittle than what I'm guessing is aluminum.
I modified my post to say 'cast aluminum' which it feels like when you flick it with your fingernail. Feels very hard/brittle.I'm thinking aluminum actually work well since it's softer and more malleable. Maybe they used thin stamped steel, which becomes brittle when too thin, or that part of the frame is only plastic.
Add me to the list. Found a crack a small leak this morning.... 15k on truck so I’m still under warranty. Those folks who are getting it fixed, are you happy with the outcome ? It’s been my experience when you change out the factory glass or frame it’ll never be right again...
Kathryn
RamCares
Can you supply more detail where and how you applied the silicone. ThankdI was able to stop my leaking myself with some silicone applied to the exterior of the window frame in areas where I could see the frame was cracked. If it starts to leak again, I will bring it to the dealer to have the window replaced.
I believe the STAR Case says it's Bakelite (tough but brittle plastic) - unless I missed something in a previous post about the window frame
I too have the dreaded rear window leak. I took it to the dealer a few days ago and their leak specialist said the seal around the window was bad. The majority of the water would gather on the headliner right next to the window on the passenger side. I also used a garden hose to confirm the leak wasn't coming from the third break light or the antenna. I took painter's tape and covered the top portion of the window and now it doesn't leak. It's going to the dealer to have the rear window replaced on Monday. Keeping my fingers crossed that this will end the leak.
Yes, There's no crack on the the inside surround. Since the window seal is recessed, there's no way to see it.Gotcha, so you have that rare leak without a visible frame crack because it's coming from a bad seal itself.
My dealer has subcontracted a glass company to replace the rear window. I didn't know the rear seat has to be removed in order to replace the window. Hopefully they do a good job and put everything back the way it was. Has far as the window beign made in China, there's an old saying. You get what you pay for.My window replacement went very smoothly, thanks to a sharp Service Dept. & factory intervention.
Photos show: old window in bed following removal, rear bench seat removed, 'Made in CN' Mopar sticker on replacement new window.
Note: 'CN' is not Canada, folks.......
I think they can do it without removing the rear seat. They would have to fold the rear seat backs forward. My Laramie seat backs can be folded forward by pulling a tiny string or lanyard in the middle of the seat back. Its hard to see and you have to reach your arm around and behind the seat back to get to it. Doing that should give enough room for them.My dealer has subcontracted a glass company to replace the rear window. I didn't know the rear seat has to be removed in order to replace the window. Hopefully they do a good job and put everything back the way it was. Has far as the window beign made in China, there's an old saying. You get what you pay for.![]()
Man, that sucks. Obviously your dealer's service department stinks. I would definitely file a complaint about that.They definitely remove the back seat. Mine were not reinstalled correctly (hardware missing, seat belts stuffed in the seats without being bolted to anything, parts missing, etc) I found this out as I was trying to reinstall my then 6m old sons car seat..
The way it worked when they did mine was dropped off a day early for stealership to remove the seat, etc. Then glass company came in to remove / reinstall new rear window assembly. Lastly stealership was supposed to reinstall the seat, etc.
It still leaked after the reinstallation due to them reusing the third brakelight seal. I was told it wa a onestime use seal and they didn't replace it.
Oh I raised hell, they fixed it, and the guy who did the 'repair' is supposedly no longer with them. It's just a headsup for everyone getting this done who hasn't read the whole thread.Man, that sucks. Obviously your dealer's service department stinks. I would definitely file a complaint about that.
When you say that the 3rd brake light seal is a one time use seal, does that include taking it off to replace bulbs ?They definitely remove the back seat. Mine were not reinstalled correctly (hardware missing, seat belts stuffed in the seats without being bolted to anything, parts missing, etc) I found this out as I was trying to reinstall my then 6m old sons car seat..
