Savagescott
19 Streak - Looks great. Can you take a couple more pics- straight front/back, directly from the side and a close of a wheel/tire?
Also - how wide and what offset are the wheels?
19 streak
I will have to get some from front and back. It's been such crappy weather here lately I haven't had much of a chance. I'll try and get some this week if the rain ever stops
PRobinson88
Minnesota
Ordering my truck soon and this is really close to the wheel/tire look I'm going for. I'm trying to determine if I can do a slightly taller and wider tire - maybe a 295/60 or a 305/55 You say you have plenty of room... Based on what you see, could you fit a little bigger and/or wider tire in there?
I’ve determined mine do not rub. I think a 305 would fit but it would be very close.
Savagescott
Folks... what do you think. I'm was going with new rims at KO2... but keep my 22" and these coopers...
I love the look, man but need more info. I’m trying to do the same thing and wondering how you’re not having any rubbing with this set up on stock suspension when others have reported rubbing with smaller tires. I sooo want to believe!
Rob696
California
What gears do you have? 3.21 or 3.92? Curious if you have the 3.21 and how it handles those tires.
I have 3.21. They handle it well, even though the tires are a little taller then stock. Would've preferred if my truck came with the 3.55 or 3.92, but with the tires being taller then stock, the gears are probably more like 3.02-ish now. Never the less, still handles it all quite nicely.
ksn240
Good to know. I've got true 34s on now with 3.21 and couldn't tell a difference over stock. Trying to decide how big I want to go. Want to do a 6" lift but am worried about 35s. Many of the 35x12.50s only truly measure around 34.5 so I was curious.
bgmshrm
35s dont look great on a 6inch.
