I just put a 2 inch lift on mine and 35 tires...I'm curious to know if anyone could see a potential issue with the dealer not wanting to warranty this...
I’m not sure about the warranty issue but your wheels/tires look great. Please share the details about your setup.
My dealer said no problem they have a third party put them on all the time for trucks sitting on the lot. I was told I would have no warranty issues if I brought my truck in for warranty service with a level kit on it. Your dealer might say something different though.
18x9x+1 Fuel podium wheels.
285/75 Falken Wildpeak AT3W
Zero lift. Zero rubing. Waiting for some companies to step up and start making OEM replacement coilovers and legit uppers!
I'v currently got a Bighorn with the 275/65/R18's (Rating is 116T). I'm considering Terra Grappler G2 275/65/R20 (Rating 116S). I do have a travel trailer that weighs about 4,500 pounds but only travel 3-4 hours max. I'm considering the 116 load Index instead of "E's" as I'm hoping to keep the soft ride quality of the stock Ram as well as save weight. My truck is 4X2 and I do mostly local and highway driving. Does anyone see any issue with this tire choice?
Thanks in advance.
Thanks in advance.
Same load rating as the factory tire should be fine for the trucks recommended loading. Both tires are rated at 2756 lbs each. Factory 275 55 20 tires are only load rated at 2535 lbs/ load rating 113. You should be fine at 116. I assume your getting new 20 inch wheels as well. You're definitely going to notice a difference with the extra rim and tire weight driving around town.
6 inch pro comp lift with 24x12
Bad Azz man. Seeing these pictures and waiting for my 6" lift and 22/37's set up with ADD bumpers and LED's to ome in is KILLING me! Great looking rigs!
I have a 2019 Ram 1500 bighorn 4x4 with the sports package. I want to put a 2in rough country leveling kit on it. But I’m tryin to figure out how big of tire I can put under it. I’m going with BFG KO2 tires Some one answered answered and said 33 x 12.5. I have a 18 in wheel i forgot to mention that. Can I fit 34 x 12.5 R18? recommendations? Was also told i could do a 295/60/18
Some dealers put a 35 1250 on trucks with a 2 inch mopar lift . That's what I would go with.
What offset do you plan on running for the wheels. A few people have posted that a 12.50 on the factory offset puts the sidewall of the tire too close to the steering knuckle. Otherwise a 305 65 r18 and 34x12.50r18 BFG ko2 should fit. If you look at the spces on BFG's website the tires are almost identical in size. the 34x12.50 is 33.5" tall and 12.5" wide measured on a 10 inch wide wheel. The 305 65 is 33.6" tall and 12.2" wide measured on a 9 inch wide wheel. Every 1/2" of rim width changes the measured tire width by about a 1/4". Making these tires pretty much identical. BFG does not make a 295 anything in an 18 inch, actually very few manufacture makes a 295 60 18 none that i know of actually. The only 295 65 18's out there are duratracs and procomp mud terrains. The majority of your 295 options are going to be for 20 inch wheels.
Im not sure about the offset. all I was planning on doing was putting the rough country 2in leveling kit and then tires. Was told I would have to do trimming with the 34x12.5in. Also would that fit on the standard 18in wheel?
I just looked at the nitto ridge grappler 285/70R18 I think it’s the same tire as the BFG KO2 34/12.5/18 but not as wide so I Should haven’t scrubbing issue in the wheelwell correct?
