Boatjockey
Found this on a tinting website. The majority of so called experts agree it is safe to tint the pano roofs. Quite a few recommend mettalic / silver tint.
Tinted glass is a major absorber of heat, and leads to a great deal of stress within the glass. Window film itself absorbs a certain amount of heat. If the combined absorption of the window film and tinted glass is very high, this can result in the glass cracking as a result of thermal stress. Thermal stress may also occur if the sheet of glass has not been installed with the appropriate amount of care. An example of this would be if the edge of the glass is either chipped or damaged. Tempered glass, or toughened glass is engineered to be four to six times stronger than average glass and to withstand higher temperatures. Tempered glass can withstand temperatures up to 470 degrees Fahrenheit. If it is exposed to higher temperatures, it will gradually weaken, making it more prone to damage. Prolonged exposure to 600 degrees Fahrenheit or greater eventually will cause the pane to shatter into small pieces. In cases where tinted glass is tempered or strengthened, the application of window film is unlikely to result in the glass cracking or fracturing.
