Bed Utility rail installation
Jako
Borough of Parks
I'm not sure why this is posted again, confusing between Nm - ft/lbs - in/lbs (10.5Nm=7.5ft/lbs.=90in/lbs)
Sensei
Fort Worth, TX
I need to tie down 2 180lb scooters. I'm looking at adding these rails, so I can tie 1 handlebar to the corner bed loop, and the other handlebar to the opposite side rail. I have to do it this way because the scooters get in the way of trying to use the front lower loops.
The question is, are these cleats all plastic or steel re-inforced? 250 lbs doesn't sound like enough strength to ratchet down a scooter to. Thoughts?
Maconi
It's not just the load rating, but also the angle that you have to be careful about. Too steep of an angle and you might cause the rail to bend/warp (or rip out altogether). I generally try to use the built-in metal loops and just use the cleats for additional stabilization as needed (although they both supposedly have the same load rating).
Sensei
Fort Worth, TX
Thanks. I decided against these rails. Instead, I installed L Track at the bottom front of the bed. This made strapping both scooters very easy as I could just tie their outside to the built-in D loops, and the center to an L track loop. Took all the way to Colorado from TX with no issues at all, and I ratcheted them down pretty tight.
jm192
Bump
I'm planning to buy a truck without the rails tomorrow, but want them. I also want a bed liner, which it doesn't come with. Does order matter?
Are the rails harder to install after the bedliner? Do you worry about when they spray the bedliner, the rails get coated?
Jako
Borough of Parks
Bump
The rails are installed using hexagon shaped rivnuts. If the "bed liner" you are referring to is a sprayed in bed liner I would install the rivnuts first as the liner material will fill the hole perimeter and is somewhat difficult to remove particularly since the hole is hexagon shape. If it is a drop in liner the Dualliner is a 4 piece bed liner that is marked with holes for drilling where the rivnuts go for the bed of the truck
See from post #61 and further
https://5thgenrams.com/community/threads/utility-bed-rails-install.9674/page-4
See step #2, "Important Notes"
rzims
I did the lineX liner and didn't install the rivnuts beforehand. Now I have to try to clean out the holes so I can install the rivnuts. Have not attempted yet, wondering how hard its going to be scraping off the bedliner....
NorthernArea51
NY
I’m going to go ahead and say I effed up the torque on these rivnutts...most of them are completely lose
Anyone know of a solution to this?
RJS
You might still be able to expand them more using this technique and save the day. Be sure to lubricate the threads, nut and washer assembly prior to turning them to tighten. It wouldn't hurt to use a couple of washer together, lubed to reduce friction either.
NorthernArea51
NY
I will give is a shot!
Those rivnuts were a mf’er getting the holes WITH lube. That should have been enough alone I guess. Shouldn’t have even tightened them. Lol
Nothing like some solid humble pie to start your Monday with lol
RJS
Yup, same with mine, tight fit but it's light gauge sheet metal so not much resistance to rotational forces.
NorthernArea51
NY
I said eff it and threw the rails on and tightened by hand. Nothing supper strong but it’s plenty sturdy. Had a helluva time just trying to get the screws to thread because Of the bed liner
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Boston
Bigger rivnuts.
