rsonedecker
- Dec 12, 2018
Can you take before and after measurements?I ordered Cooper’s STT Pro 295/70R18 they are 34.49 exactly i hope they don’t rub will do the install next week on Fuel’s D579 Vector 18x9 Wheels along with the Mopar 2 inch lift on my 19 Rebel, Wish me luck!
I think you're going to run into an issue where the bilstein's spring perch doesn't fit the fox shocks on the Mopar kit. During the install, you have to remove the spring perch from the shock you are replacing, and put it on the fox shock - my rough measurements from under a vehicle says they are slightly different than the regular Hitachi (non-rebel) shocks which are what the Mopar kit was designed to replace. If that's the case, you might have to grab some used 2019 shocks off eBay that still have the spring perch on them - the spring perch is not available separately from Mopar as they are part of the shock assembly. You'll find most of the used shocks on eBay missing this part because they probably exist on eBay because someone installed the Mopar kit.
