kliffy77
- Dec 12, 2018
Mopar themselves say "not for Rebel or Air Suspension"on the kit.
Shame I guess ill return back
hubcentric options are availableEvery aftermarket wheel is lugcentric.
Cool, probably smart move - but dang it...I was secretly hoping to prove why the mopar kit doesn't work on the rebel! (haha, jk)Just an update: Mopar Lift returned, Readylift ordered.
No they just asked me why.^^^. Good deal, did they give you a hard way about returning the Mopar one ?
At least they sold it to you in the first place. They wouldn't sell me, or install the factory Mopar 2" lift because mine is a quad cab and the product description says "crew cab". They even called Mopar and they confirmed it will not fit a quad cab, although no one at FCA from dealer parts to corporate can tell me why it won't work. I sure will be happy when Bilstein or FOX starts selling their ride height adjustable strut replacements for the 19No they just asked me why.
Yes, but your cv angles will be terrible and more prone to failure.Could one install leveling spacers to the front, in addition to the mopar 2 inch suspension lift?
Pics!FWIW, just installed the Mopar beadlock 18 inch wheels and I'm running 295/70/18 tires with no rub.
I have the offroad package with no lift. TIres work out to 34.3" and so far so good.
I'll add a level to the front end to get the right look. Still undecided on the best way to level the offroad package.
I was thinking about using the Zone Offroad kit that includes their control arms.
Did anyone end up putting 12.5" wide tires?
I am planning a 2" Mopar lift on my Big Horn, stock night edition wheels with 1.5" spacers to run 35 x 12.5.
Lots of talk about this and no one ended up posting results!?
-B
35 will fit Max width is 12 if you go more than that the tire will rub and you need a small mod.
stock wheel, any wheel with or without a spacer 12/5 tire will rub.Do you mean with stock wheels or even with a spacer? I was planning to measure my wheels and lugs in order to get the smallest spacer possible. I think my wheels might have pockets in between the lug locations to help with using thinner spacers so the stud can pass the mounting surface of the wheel slightly.
The more negative offset you have on a wheel (bigger spacer basically), the worse it's going to rub on the fenders. Bigger spacer = wider turn arc of the wheel.Do you mean with stock wheels or even with a spacer? I was planning to measure my wheels and lugs in order to get the smallest spacer possible. I think my wheels might have pockets in between the lug locations to help with using thinner spacers so the stud can pass the mounting surface of the wheel slightly.
Untitled by RAM RSM, on Flickr
2020-01-04_03-39-10 by RAM RSM, on Flickr
2020-08-08_06-36-28 by RAM RSM, on FlickrMy bad, i keep thinking not a lot had changed down there other than wheel choices but the more i read about the new gen truck the more i realize most of that stuff have changed.@Ram1500rsm pretty sure the suspensions and fenders are different between 4th and 5th gens. Not to mention that I don't think any 17's will fit on the 5th gens although that's not that important. A 17x9 +0 offset wheel will perform the same as an 18x9 +0 in terms of rubbing with the same tire.
