I’m pulling a new Transcend Xplor 265BH with a 2019 Limited. 33ft long, 6734 dry with 654 tongue weight (as built per VIN sheet from factory). It’s probably around 8k loaded. Started with an Andersen and hated it, so swapped it out for a 10k Equal-i-zer hitch. RV dealer setup the hitch with trailer relatively loaded but no water, and truck empty. Driving it that way with only me in the truck, it pulls like a dream.
Took it about 45-60 miles this weekend fully loaded, and it was a completely different story. Outbound I had a full water tank (62 gal/516lb) and a loaded truck with me, wife, son, 2 dogs, and 65 quart RTIC with drinks and ice. I was getting pushed around like crazy, white knuckling it at 55 mph, & probably had a good 20 mph cross wind. I saw a CAT scale, so I did a single weigh just for reference, as I couldn’t really change anything at that point and only had another 10 mins to go. I was overweight on the truck, but I don’t have any unhooked weights to compare to.
Coming home, I had dumped all the tanks. Interesting thing about this trailer, the fresh water tank is at the very back, so that’s 516lbs of back end weight gone. I stopped at the same scale and weighed again. The return trip home felt completely solid and comfortable, and if it weren’t for the scale showing me being overweight, I never would have known and wouldn't be looking to change anything.
I'm thinking the water in the trailer made me tail heavy and the load was therefore unbalanced. I’m going to do another round of scale weighing before the next trip. Hopefully I can move some weight (the cooler) from the truck bed to the trailer over the axles, and also adjust the WDH to get the measurements closer to the GVWR, and shift more from the drive axle to the steer axle. Max load capacity is 1154lbs, GVWR is 7100, but GAWR is 3900 front and 4100 rear for a total of 8000 GAWR. It does strike me as a little odd that there is a 900 lb difference there. If it drives comfortably and solid, do I really need to be all that concerned about being 260 over the GVWR even though it’s under the axle limits? Any advice?
