silver billet
- Apr 18, 2019
You question wasn't addressed to me, but I've been using the Andersen WDH so I'll chime in. I pull a 32' travel trailer that weighs about 7500 lbs loaded.
I like the hitch a lot as far as weight, noise, mess, and ease of hookup are concerned. I'm not impressed with its sway control performance. Like you, I feel like I get pushed around by crosswinds and passing semis, though it's never been bad enough to trip my stability control. I don't know that it's any worse than a typical spring-bar style WDH as far as sway is concerned. If you pull a giant, heavy sail with a 1/2 ton truck you will feel it pushing you around.
My experience has been that everything is great up to 55 mph. Above that speed it depends on conditions. On a calm day 60-65 mph is fine. On a day with 15 mph winds, 60 can start to feel a little loose and 65 is unpleasant. It's not white-knuckle driving but the truck requires constant correction and it's tiring to drive. Adding weight to the front of the trailer and more tension on the chains (= more weight returned to the front axle) helps.
I think the Andersen is fine for shorter distances and lower speeds (i.e. you stay off the Interstate). At higher speeds it would probably be fine with a smaller trailer or a flatbed (i.e. something with a smaller profile), or if I were pulling with a 2500. As it is, though, I'll be replacing it with a ProPride 3P ($$$) in order to get a more relaxed towing experience. The wife and I want to travel while towing the trailer, and right now I don't really want to go further than an hour or two away.
Just a thought, do you have the bars absolutely level/flat on top of the clips that holds them tight? If the bars aren't level, then only 1 end of the bar (fraction of an inch) is contributing to the sway control, whereas if they are perfectly flat then the whole clip (several inches on my Husky hitch) adds the correct amount of friction for sway control. You can quickly double check by looking for grooves on one end of the clip or the other. If one end of the clip is badly worn down, then the bars aren't level and they won't add enough friction to prevent sway.
