Hi all,
I feel like this is going to be an issue with these trucks for a while.  The temperature at the vent can meet specs, but still feel weak or not cold enough.  I found this quote on another website:
"I don't know if you've worked on cars professionally or not, but I can tell you that if you let customers' vehicles go with a 54* vent temp, SOMEONE is going to be working on that car again. Yeah, if I go pull a book out, I'm sure I can find a chart that says 50-60* is 'normal' for an 100* day, but I can tell you flat out that I've stood in a 100* shop, measured vent temps in the 50-60* range, and fixed them. 54*, even when it's a 100 out, doesn't feel cold; probably because the air has dispersed and warmed significantly by the time it even gets to you (keeping in mind temps are usually measured ~6" down into the vent because of the design of most tech's thermometers). "
I live in Central Texas.  Ice cold A/C is a must for me.  If I were to buy one of these trucks today I think I would buy one off the lot.  I would wait for a hot, sunny day, and test drive it while I physically take a thermometer to it and check the temp at the vent.
These trucks are fantastic, but I must have great A/C.
