techieanalyst
 - Jun 29, 2018
2018 F150 was weak as well, I’d say this 2019 and the ford were on par and as long as I use auto the ram does just fine
This may have been mentioned previously but if I take don't use Auto is the expectation that I am in control of the fan speed and temperature of the air coming from the vents? If that's true then something doesn't make sense because after 15 minutes of driving I had the fan speed at 1, and the temp at 68. A/C light was lit. The fan speed slowed to almost nothing and vehicle started blowing warmer air. If I lowered the temp it became cold again and fan would blow at speed 1 as normal. I would expect that in Auto but not when the Auto light is off. Am I wrong?
Turning AUTO off doesn't mean the air coming from the vents will be a constant 68 degrees. If the cab gets too cool, the air will get warmer to keep the cab around 68 degrees. The fan speed shouldn't be changing without your input though, if in manual mode.
Interesting, because I had the opposite experience. Ford was cold so quick and Auto mode worked great. The RAM takes forever to cool down through the vents and the Auto mode is just weird blowing at jet engine speed even when the outside temp is lower than A/C set temp
same here. very happy with it in auto. did it with my 13 also.I feel very fortunate that my A/C seems to be working perfectly. I just leave it on Auto at all times.
