Last week I had the opportunity to try out the AC on a handful of new Rams on the lot at my dealer. A buddy of mine was keeping the sales guy busy with the 3500 he is looking to buy, so I went along with him to the dealer and I walked all around the lot by myself, trying the AC on a total of five of the 2019 (DT) 1500s, two of the 2018s (one a 1500, one the 3500 my buddy test drove), and finally compared AC performance of those seven new Rams to my buddy's existing 2006 Ram. The five 2019 5th-gen (DT) trucks I tried had build dates 4-18, 6-18, 7-18, 8-18, 9-18, and I made sure none of them had the panorama roof, just solid steel roofs, and I made sure every one of the trucks had its AC controls set to Max AC, set to the coolest temperature setting on both driver and passenger sides, and fan on its highest setting. I didn't write down the build dates of the two brand-new 2018s (DS - 4th gen). It was sunny, outdoor temperature was 75 °F [24 °C], relative humidity around 40%. I didn't have a thermometer with me, but I didn't really need one, because I was just looking to find out qualitatively how quickly the five 2019 DT trucks began to blow cool air, and how they compared to the two 2018s and the one 2006. Here's what I found:
All five of the 2019 (DT) 5th-gen trucks had what I would call very poor AC performance. They all took much longer to begin blowing cool air, and none of them got the air very cold, just what I would call relatively cool...not acceptable for a 75 °F, 40% relative humidity day. On a scale of 1-5, with 1 being worst cooling performance and 5 being excellent cooling performance, I'd rate all five of the 5th-gen 2019 DT trucks a 3. I'd rate the two 4th-gen 2018 DS trucks a 4, and I'd rate my buddy's 2006 a 4.5. I will say that the air distribution throughout the cabin on the 2019s was noticeably better than the 2018s, and on two of the five the 2019s I noticed that the air blowing from passenger side face-level vent felt slightly cooler than the air on the driver side vent (i.e. the two vents immediately on either side of the screen in the center of the dash).
I know someone will say "but it's a bigger cab now, of course it takes awhile to cool down", but that is not the point at all - I wasn't timing how long the entire cab took to cool down to a comfortable level, I was comparing how long each truck took before it began blowing truly cool air out of the face-level dash vents. And someone will say "but it's the new refrigerant that the government has mandated, it's not as efficient as the old refrigerant", but that is also irrelevant because (a) Ram has been using the new refrigerant across the board since around 2014, and (b) Ram supposedly increased the capacity of the 2019 DT truck AC system by 25% to account for the 5-10% reduction in efficiency of the new refrigerant and the larger cab. If they had truly increased capacity of the 2019 DT's AC capacity, then they should begin blowing cool air even more quickly than the outgoing 2018s.
I'm not trying to bad-mouth Ram, and I'm not trying to convince anyone to not buy a 2019 DT Ram. I'm just sharing my practical, real-world results, for whatever it's worth to any given individual. If you don't like what I've said here, I strongly encourage you to do your own real-world testing and draw your own conclusions.
Again, from my point of view, this has nothing to do with how long it takes to make the cabin as a whole feel comfortably cool. It's a matter of (a) how long it takes to begin blowing decently cool air from the vents, and (b) how cool that air ultimately becomes. In my little bit of testing, there is no doubt that all five of the 5th-gen (DT) 2019 1500s were noticeably poor performing AC-wise compared to roughly equivalent 2018s, my buddy's 2006, and my family's 2013 Mini and 2005 Prius. The new 2019 5th-gen Rams, at least so far, suffer from fair-to-poor AC performance, which is not at all what one has the right to expect from the most advanced half-ton pickup truck ever designed or built. Sorry this is such a long post, but I had a fair amount of info to cover.
UPDATE Nov. 02, 2018: Test drove a Laramie Longhorn today, build date 10/18, just arrived at the dealer yesterday afternoon (11-01-2018), happy to report that the air-conditioning worked beautifully in that one truck.
