Cableline01
Thanks much help didn’t want to get a radio I can use.
How much was it for the module?The spare module showed up today. It's UCX but will work just fine on the US vehicles. The only thing you're losing from what I'm told is Guardian.
It's available and shipping will be $15 CONUS
Isn't the US version cheaper? Why would you buy a non-compatible version for more money?It cost me $966. I'm going to let it go for what I paid plus $15 shipping priority in the US
Oh wow... Didn't know that... Thanks for the info!It's compatible with the exception of Guardian. The US version that's no longer being made is $1,180, and you cannot get them.
I understand the modules are currently restricted for purchase but there not being made? What are they using in new trucks?It's compatible with the exception of Guardian. The US version that's no longer being made is $1,180, and you cannot get them.
They are being made, but the UAX modules are restricted for sale. Parts get revised all the time with either the last letter of the part number, or a new part number all together.I understand the modules are currently restricted for purchase but there not being made? What are they using in new trucks?
That was the point I trying to makeThey are being made, but the UAX modules are restricted for sale. Parts get revised all the time with either the last letter of the part number, or a new part number all together.
Good for you bro!!!everything in now my cable got here today will be doing this tomorrow hopefully....Only issue don't know a lot about repining a harness......
Is there a pic somewhere that i could use as a referenceGood for you bro!!!
So jealous
Repining the harness is the easiest part..
Pry the red face off of the connector. Then insert a paper clip in the front underneath the terminal to pry up the plastic terminal lock. You’ll push in on the wire while prying up the plastic locking tab, then pull on the wire once the tab has cleared the terminal.Is there a pic somewhere that i could use as a reference
That module looks brand new. Where did you get thateverything in now my cable got here today will be doing this tomorrow hopefully....Only issue don't know a lot about repining a harness......
Can I leave the security bypass installed or do I need to remove it?Every time you need to get access to the computer, You need the bypass.
After the change, you can remove it.
You can leave it installed but the Uconnect app isn't going to work and Dealer's wiTech need the SGW module to be connected for it to communicate; Hence the dealer won't be able to service your truck unless disconnected.Can I leave the security bypass installed or do I need to remove it?
I'd just assume leave it there if it isn't hurting anything.
Thanks
Vic
I circled the plug for the Brake controller, It's already there. You do need to get the TBC module but it's pre-wired.this unit came with brake controller is that something I will have to get later because I don’t think my truck came pre wires
You can use zip ties...I’m assuming I’m going to need to find mounting hardware for the new module because my module for my 8.4 is mounted to the whole screen unit
