bennekm
- Jun 5, 2019
2019 Apex Ultra Lite 293RLDS
UVW: 6440lbs (~7400 loaded)
GVWR: 7800lbs
Tongue: 832 (1,000 w/propane,batteries,cargo)
33.11ft length 10.7 height
Tows perfectly up steep grades with no lack of power, minimal sway with anti sway hitch installed. My truck has air ride so it sits level throughout. I have to be minimal of cargo in the cab/bed due to payload restrictions. My temps are in what i consider normal range for when towing a load, wish i took a pic of it to compare, maybe next time ill get a chance. The trailers height is a bit shorter then most other TTs so the wind resistance isnt as severe which i believe helps me with control.
I took a day to weigh my truck and trailer connected, both of them separate, as well as weighed my trailer and its hitch separately so i know exactly what and where to load cargo.View attachment 51966
I have a very similar trailer. What hitch system are you using?
