Updated 2" Mopar Lift/Level Kit - Discussion
Ram1992
Houston TX
I’m not sure I want to add that second spacer.
The BJ appears to have excessive angle(see attached picture). Not sure on the CV axles.
What are y’all thoughts?
should I add 1/4” top hat spacer or
add the second ring at the bottom of the spring perch . FC1F3DD4-A4C1-4B3D-A553-68F5425A9B95.jpeg 592B7BBB-1781-4BC4-9F9D-45A69A92FF56.jpeg FC1F3DD4-A4C1-4B3D-A553-68F5425A9B95.jpeg
Alxmlr789
texasvolfan15
Might be a dumb question, but seems like most people are getting close to level with the off road springs...can I do that method if I only had a 2WD truck though?
Kendragon
The cost of the lift kit is $1,250 from 3 different dealers I checked. The cost to install including the alignment has been around the $500 range for a total cost pushing $1,800. I will be getting mine done in the next month or two. Love the look.
I know this is an older post, but my dealer service dept wanted 2464.00 for the kit and the install. No way I would pay over a grand for that
skidoosctt
Just had mine done today. Paid $995 for lift from a Dodge dealer on Ebay. $400 to install, and adjust headlights. $90 for alignment. But the alignment ended up being free for buying the truck there.
Ram1992
Houston TX
Did you get the updated kit?
when you get a chance post a picture of the truck.
BiGJZ74
American Canyon, CA
That's pretty much what all the NorCal dealers are quoting..I've had labor quotes as high as 2K which is absurd.
Jeffjad
Southwest PA
I paid 1,200 for the kit and a local shop is charging 600 for install including alignment. I don't trust my local dealer service dept to do the install.
skidoosctt
If you look up the lift, it says 4 hours to install. That's exactly what my dealer charged me. It took them a little longer and they still only charged me $400. I would think anywhere between $400 to $500 to install would be a fair price. Anything more than that and there ripping you off.
Jeffjad
Southwest PA
Thanks for the info, I will show that to the local shop doing mine and maybe they will take that into consideration. I only have a quote of $600 right now as my lift is getting done next week so that number could change.
skidoosctt
Your welcome. $600 isn't terrible. Comes down to what there shop rate is per hour. Plus make sure they adjust headlights and if going to bigger tires they calibrate speedo.
skidoosctt
$600 is a good price. It took my dealer over the 4 hours. Plus the alignment was $90, that I got free for buying the truck there. So if they had charged me the full price, it would have been close to $600.
Alxmlr789
I typically charge 300-500 for a lift like this at my home shop, depending on if I have to bust out the spring compressor. Dealers and actual shops can do it faster because they have those commercial spring compressors - I have done several chevy lifts with pre-installed springs on lifted struts for 400.
Ramblackout
Who in central Florida has had this lift put on and can reccomend a shop. Price, expertise, alignment, headlight leveling, radar cruise adjustment, speedo correction for larger tires. Who's the go to in FL?
Alxmlr789
I live in Maitland and have a shop at my house. I can install the lift for 400 but that’s where i stop, and recommend an alignment shop (Philips tire and auto in casselberry is my go to for trucks and my race cars).
Speedo correction, i would get a rough country tool or Tazer because the dealers around here will tell you no. I went with a Tazer for addd features. headlight correction i passed on, but can do it if needed. I haven’t heard about the radar cruise adjustment, as all that is needed is a speedo adjustment.
2Fast-4U
I see that the Mopar 2" Lift Kit, P/N 77072424AB is on sale at BAM Wholesale for $1083.13.
Now that winter is gone, I need to get this installed. Need a trustworthy dealer for an install price of $400-500 + an alignment. I am hoping that the kit is a single ring kit finally and not the interim 2 ring/shock kit. Just not a fan of that. The longer shock body before the neck down and a single ring is the way to go. Has anyone had the kit installed and only has 1 ring on the shock?
