Mopar lift?Rear is 25-7/8” and 25-3/8”.
Currently at full tank.
Yes sirMopar lift?
CV looks fine, no worse than a 3.5 readylift. The ball joint angles don’t scare me either.I’m not sure I want to add that second spacer.
The BJ appears to have excessive angle(see attached picture). Not sure on the CV axles.
What are y’all thoughts?
should I add 1/4” top hat spacer or
add the second ring at the bottom of the spring perch . View attachment 49514 View attachment 49515 View attachment 49514
I know this is an older post, but my dealer service dept wanted 2464.00 for the kit and the install. No way I would pay over a grand for thatThe cost of the lift kit is $1,250 from 3 different dealers I checked. The cost to install including the alignment has been around the $500 range for a total cost pushing $1,800. I will be getting mine done in the next month or two. Love the look.
Did you get the updated kit?Just had mine done today. Paid $995 for lift from a Dodge dealer on Ebay. $400 to install, and adjust headlights. $90 for alignment. But the alignment ended up being free for buying the truck there.
That's pretty much what all the NorCal dealers are quoting..I've had labor quotes as high as 2K which is absurd.I know this is an older post, but my dealer service dept wanted 2464.00 for the kit and the install. No way I would pay over a grand for that
I paid 1,200 for the kit and a local shop is charging 600 for install including alignment. I don't trust my local dealer service dept to do the install.I know this is an older post, but my dealer service dept wanted 2464.00 for the kit and the install. No way I would pay over a grand for that
Thanks for the info, I will show that to the local shop doing mine and maybe they will take that into consideration. I only have a quote of $600 right now as my lift is getting done next week so that number could change.If you look up the lift, it says 4 hours to install. That's exactly what my dealer charged me. It took them a little longer and they still only charged me $400. I would think anywhere between $400 to $500 to install would be a fair price. Anything more than that and there ripping you off.
Who in central Florida has had this lift put on and can reccomend a shop. Price, expertise, alignment, headlight leveling, radar cruise adjustment, speedo correction for larger tires. Who's the go to in FL?
