Thanks again for this! I appreciate you taking the time to send it.Very easy to hook up, straight forward.
I ordered the one with the LOC pre-wired.View attachment 48382
Did you end up using this? if so did you do any pics or have any adviceI found the product I will use to being the upgrade process. This allows you to keep the factory deck, but adds a ton of advanced features we wouldn't have otherwise (like timing). This also explains why upgrading modern systems is so complicated.
For the 2019 Dodge Ram (which is supported... many vendors don't know this yet but I spoke with Maestro directly), we need the ACH4 Harness.
Ok so I have the base 6 speaker with ANC, I ordered the ANC-CH01 bypass harness already. Planning on adding 2 10" subs in a Fox Acoustics box with a mono amp..... obviously I will need a LOC which is fine so I guess my question would be which wires on the bypass harness do I tap the LOC into and which wire is used to for the remote turn on for the amp? I can't see spending $95+shipping for a $20 harness and $15 LOC when I can do it myself.
Just received my Wavtech link2 loc, and was wanting to know which wires in the B pillar are for the rear door speakers, Anybody have a wiring schematic handy?
This afternoon I've started to install the latest model of "Focal FLAX EVO PS 165 FE"
The pictures below are under progress, basically I'm taking my time to fit all the components to an optimum location.
And the door panel fits nicely
I can't believe how perfectly the tweeter fits on the factory mounting trim panel without modifying nothing !! Looks like it was made for it.
	Change in subwoofer box design thanks to the 5thgen Ram Facebook group. Building it tomorrow.
What do you plan on putting in there? I am going to build a ported enclosure. But i would of loved to not have to trim my Ram mats, and keep it inside of the enclosure. But not enough volume. Deciding on a JL 12" TW3 or Sundown 10" SD4. Torn.
Sweet. Looks good. What panel is that?
I picked up a Focal K2 Power 165 kit for my Ram 1500, still deciding on where to put the tweeter. Are you doing any sound deadening?
It looks like you could increase the height of your box of at least +1" or more.
	Do you think the color combo for the speaker wires will be the same on the 2020 bighorns with no anc 6 speaker system?For the few folks who may just want to add amplifier.... Here are the pics of where I connected to get a line audio "IN" line to the amplifier. Again, No ANC issues what so ever.Drivers Side.... kick panel removal and the wires are located there, gently pull off the black OEM tape and go through the big bundle of wires twisted together you will find the Dark Grey wire with Yellow stripe (+) and the Grey wire with Purple stripe (-) Splice into those... you have your left signal.
Passanger Side... Kick panel removal - as you go up the wall sits a wire harness... patch right into the twisted Dark Green with Yellow stripe (+) and next is the Dark Green with Purple stripe (-) ... done deal.
Run those under the carpet neatly and on to your Amplifier..
View attachment 15509View attachment 15510
Thanks!
Thanks!
Will polarity matter when hooking up a LOC for just one sub?
