NC Rebel
- Jan 31, 2020
Please, let us know your hardware version, since you have a 2020 it is probably 29N3.
Yes from what I can see looks like 29N3GL
/de-Lurk
Nothing yet for me.
Hardware ID - CNSC29NFGL
Soft Ver - 18.45.40
2020 Limited (don't recall build date, can go look)
And yes, have issues including no App remote start etc.
WL
\re-lurk
Not sure that’s exactly true. I have a 2020 Limited unlit in 11/19 and no update. NFGLTook mine to the dealer. Tech there said that it's based on the radio model # and the older version will NOT get the update. That is exactly what we're seeing from members reporting here. Early 2019 models aren't getting updates. I'm OK with that since I have no bugs, but some updated functionality would have been nice!
Not sure that’s exactly true. I have a 2020 Limited unit in 11/19 and no update. NFGL
My 2019 was built 10/08/2018.....so I have the original hw before any revisionsI also have a 11/19 build Limited, however my hardware version is N3GL and I did get the update. My build is actually 11/06/2019, what day was your build? Maybe we can pinpoint the actual day FCA changed to the newer hardware.
It appears that the only units getting the OTA update have a hardware version CNSC29N3GL, a version that appears to be in only 2020 MY trucks with a build date sometime in Nov '19 . Only time will tell if this holds true, but for now, that is what we are seeing.
18.45.40Mine is running 18.27.17 (older than @Edwards). But my build was a month or two earlier as well. What version are you on?
Misread mine...built 24 October 2019. NFGLI also have a 11/19 build Limited, however my hardware version is N3GL and I did get the update. My build is actually 11/06/2019, what day was your build? Maybe we can pinpoint the actual day FCA changed to the newer hardware.
Pretty much horse crap if they can't fix everyones..I guess I'm screwed at least for now.
2019
3-19 build
29NFGL hardware
18.45.40 current SW
At the dealer today. They told me there would be no updates--that they could only "reflash" the same software on to see if it helps. Otherwise they will order a new screen to replace it if the problem persists.
I had the backup camera/black screen issue for a while, but haven't seen that lately. The biggest one for me is the bluetooth drop out issue, which happens A LOT.
