PLEASE Let me know if it works & what year Model You have with your 12" screen.
A video of it working would be huge. I was told if you have the 360 Camera it will NOT work however I would assume it uses the Cargo Cam input.
I also could not confirm if this gave you a Video input Only & what activated it (back button or screen off or??)
You tube video is worthless as it doesn't show a movie playing with sound.
I would assume it does full unlock for nav in motion. Also
Trust you can share your feedback
If it Helps I learned years ago if any vehicle had HID Lighting especially aftermarket using Video in motion. Via WIFI it caused a feedback Squeel that's LOUD.
I don't know if this is wifi only or HDMI or either.
It's not the cost, stopping me from purchasing it's taking the dash apart to install a maybe device.
Please share your results & thank you.
This is my 1st board so I don't know how to even get notifications when you reply??
My "plan" is to use composite video out from pi to display on cargo cam. If i find the right codes, i can do video in motion via the can bus.
Ill be able to pass audio through via bluetooth from phone to pi, pi bluetooth to head unit, no rca cable audio howling.
Once i work through canbus instead of obd2, i can put the sgw back and take my mx+ out, reducing complexity and build cost.
Via canbus ill be able to do all kinds of crazy fun.
Text to evic
Steering wheel controls(inputs)
Global window controls.
Remote startstop
Lights controls
Ignition interrupt
Throttle based exhaust cutouts (which i intend on sourcing from atlanta speedo)
Change fuel reserve/tpms thresholds.
Walk away locking.
"Holy ****" lighting of drl,low,fogs all at once for off road night driving.
Random silly stuff as i think of it.
Possibly even get into the throttle controller for pedalcommander type stuff (very sketchy here, i dont want to poke at drveline/safety systems much).
