Could you post the part number to help others out?so i found one i think that will work. its a salvage one for $131.00
Thanks
Is there a spot on your windshield for the camera to "see" out of ? Like there is for the rain sensor.The part number for the interior mirror with the camera for smart beam is MOP-68312206AA MIRROR, INSIDE REAR VIEW, 2019-2020 (Mfr. #: 68312206AA). I purchased mine through Summit Racing Equipment.
Initially when I put mine in and used the five AlfaOBD commands that are posted online to activate it my tailgate would lock up and couldn't open it. I went through line by line and found out what was causing it to happen. It was the third AlfaOBD line LIN & Misc: Smart Beam Present (AHBM). Once I changed it back to NO the tailgate worked again and the smart beam worked. View attachment 45764 I
I also just got my rain sense wipers to work once I switched out the sensor that came with the truck.
It actually looks under the frit. If you look at the windshield from the front of the truck, there should be a square cutout on the mirror shroud on the bottom right. That's where the camera would beIs there a spot on your windshield for the camera to "see" out of ? Like there is for the rain sensor.
Yep, i checked and see the spot that the camera goes into. So all you added was the mirror with the camera (Part Number 68312206AA), and enabled the Smartbeam? Is the required wiring harness in the headliner or is it the same harness to the existing mirror?It actually looks under the frit. If you look at the windshield from the front of the truck, there should be a square cutout on the mirror shroud on the bottom right. That's where the camera would be
How do you like the smartbeam. I've seen people say it doesnt work well for them but they all seem to mainly live in city.Yes. You use the same connection as the old mirror and enable using AlfaOBD.
Yes, thanks. I just checked the wiring diagram for the mirror and see that it's basically a Bus connection and power supplied on the connector. I ordered the new mirror so will see how it goes with that and the rain sensor I have on order also.Yes. You use the same connection as the old mirror and enable using AlfaOBD.
The smart beam works as it should. The only issue is when road signs reflect my led headlights enough to turn off the high beams.How do you like the smartbeam. I've seen people say it doesnt work well for them but they all seem to mainly live in city.
I'm just a country boy, I rarely go into town (not even city, just town). So I figure it will work pretty well for me. Especially since if I do go into the city it's nothing but backroads for me to get anywhere.
Which gives me plenty of time to play with the electronics in the truck. I'm thinking of sniffing out the canbus and see if theres anything interesting there for me
Yes. Auto high beams is a better name for it.Hate to ask this, but what is smart beam? Is that for auto brights? Googled it but couldn’t find an answer.
I don't think that is the right part. Here is my 2019 part. Is this for a 2019/2020?The part number for the interior mirror with the camera for smart beam is MOP-68312206AA MIRROR, INSIDE REAR VIEW, 2019-2020 (Mfr. #: 68312206AA). I purchased mine through Summit Racing Equipment.
Does yours have lane sense, adaptive cruise & all that? If so, you have different hardware than the trucks that just have smart beam. Not sure if they use the hardware for lane sense for smartbeam or if they also use the same cameraI don't think that is the right part. Here is my 2019 part. Is this for a 2019/2020?
If all you are looking to accomplish is to have smart beams/auto high beams this the right part. It is all I changed to have this work. This was done in a 2019.I don't think that is the right part. Here is my 2019 part. Is this for a 2019/2020?
Yeah, with those options there is different hardware behind the mirror. Again, I'm not sure if those take the place of the smartbeam camera that hulk listed the PN for. But he is correct, that is the right PN. There are a few different ones depending on other features (assist & sos for one) but they all include the same smartbeam camera. If someone that has lane assist & smartbeam can chime in on if they have the camera from that PN that should settle it.My truck does have the lane sense,adaptive cruise. The one I pictured is the camera part behind the rear view mirror.
