buffalobill
- Jan 28, 2019
you might need a different windshield
If you are talking to moparleo51 he posted a picture a few posts above of his windshield, if has a humidity sensor already so hes good.you might need a different windshield
Ok, so had a chance to install the new sensor today.
Part number I bought was 68298334AA.
Enabled the following:
VehConfig 2-Rain Sensor Present
CustSetMenu 1-Rain sensitive wipers CSM
Tested with a squirt bottle and....
I now have rain sensing wipers!
So to confirm, if you have auto climate control and not rain sense, the sensor located under mirror shroud is a humidity sensor only to tell the truck when to turn on defrost.
The part number above is the rain sensor and humidity sensor in one. No extra wiring necessary, plug and play.
There is a bracket that the humidity sensor is already clipped into. Two metal clips, one on each side then the humidity sensor comes off. Same bracket will be used with the new rain sensor.Excellent info! Part ordered! How does it mount to the windshield? It's there some kind of bracket or mount or anything else that needs to be ordered? I won't have my truck until Thursday, but would like to get everything in hand when I get it back. Thanks!
No problem. I had the easy part. Thanks to -RotorDemon- for the part numbers, and everyone else for the legwork. All I had to do was fork over the money for the new sensor to see if it would work, haha.
I believe you can turn it off in settings and go back to timer mode at any time, right?So how does the wiper function compared to the timer mode? Happy you did it ?
Jury is still out. Unless its pouring out I'm very much a turn on for one wipe when I need it kind of person. The rain I had yesterday was too intermittent for me to mess with the different sensitivities.So how does the wiper function compared to the timer mode? Happy you did it ?
Didnt see this as I was typing my reply. Yes. You can. If I decide I dont like the rain sense I can turn it off. And I'd just be out the $50ish bucks for the sensor. But I kept the old one so I guess you could say I have a spare humidity sensor lolI believe you can turn it off in settings and go back to timer mode at any time, right?
Sent from my Pixel 2 XL using Tapatalk
outside temp is in th driver side mirror.I would guess that it also senses outside air temp. Do you have a readout for temp in your truck?
Do you think the wiring is there for the "smartbeam" mirror for the auto highbeams?Jury is still out. Unless its pouring out I'm very much a turn on for one wipe when I need it kind of person. The rain I had yesterday was too intermittent for me to mess with the different sensitivities.
I could see liking it in 1 or 2. But it did work well. When I was testing with a squirt bottle if I hit it with a short burst it would only wipe once or twice, a steady stream it would speed up and wipe until i stopped.
Once I get my hands on a smartbeam mirror I'll be set. 90% of my driving is back country roads where high beams are on unless I'm passing a car which can be miles between.
Only problem is alfaobd can be addictive. I'm finding myself wondering what else I can add and activate lol.
But overall I'm happy I did it. $50 for anything on these trucks is chump change, it works good so far and if I decide I dont like it I can turn it off in the settings and go back to the intermittent wipers.
I believe so, yes. It communicates on the can bus and I believe it is through the same wire the rain sensor communicates through. On 4th gens if wiring was available for one it was available for both and the smartbeam mirrors are listed as compatible with both 4th and 5th gens.Do you think the wiring is there for the "smartbeam" mirror for the auto highbeams?
Let me correct that and say if truck already had a humidity sensor, yes I believe it does. If not, I doubt it. We may get lucky and it be like the 4th gens where the harness runs right under the front of the head liner and a harness can be made/bought to tap in there to get the wiring needed for smartbeam and rain sensor if the truck doesnt have the wiring present at the mirrorI believe so, yes. It communicates on the can bus and I believe it is through the same wire the rain sensor communicates through. On 4th gens if wiring was available for one it was available for both and the smartbeam mirrors are listed as compatible with both 4th and 5th gens.
I dont know all the ins and outs of the can bus systems but I do know it is an internal network for the truck. Gone are the days where each component needed it's own wire to function. Being a network, packets of data from multiple sensors can be sent with the same wire.
Yep, we covered that last April when the thread just started.outside temp is in th driver side mirror.
Where did you find one of these at?so i found one i think that will work. its a salvage one for $131.00
