A-TEAM
- Jun 14, 2019
Thanks for the replies. 50 miles home and 1 was still on 3off. I removed the spare and hard reset the truck (positive batt cable removed for 20 minutes) and same thing. Seems to idle smoother and run better after the reset too. Maybe ive got some damaged sensors. Going to get try a few more miles to see if they pickup, if not ill probably swap them out, or take it to the dealer, there is an open recall on mine about the cruise control software. For the record I swapped the tires to 275-60/20 so they are bigger than factory and cooper discovery at3 4s which has silica compound, not sure if that can block readings or something.
