Updated 2" Mopar Lift/Level Kit - Discussion
ok so for the members with the newer updated 2 inch mopar lift ...queston
the box nor my invoice has the ab at the end of the part # ..... however the front shocks have a ab at the end of the part # 68323528ab for the front fox shocks and part # 68323529aa for the rear fox shocks
my box has a pack date of 10/2019 so I would assume its the updated length front shocks ?? anyone with confirmation would be awesome .... also the kit came with the 2 spacers but I no longer need those correct ??
I was in the same situation and assumed since the struts part number ended in AB it was the new kit. I installed the lift without using the spacers and it only netted ~1.25" of lift in the front. So I added the spacers and now it sits a little over 2" of lift in the front.
so bottom line I guess we should install the spacer on the shock even if its the "new kit" ?
Sounds like a plan lol ... so here’s the before pic
Thanks so much guys ... saved me lots of heartache and trial and error lol
plan is the mopar 2 inch kit with the spacers
Orp front springs
Fuel rebel matte black 20x9 +1
Nitro grapplers 35x11.5 20s
I’ll post after pics soon
^^^. Did you get your wheels / tires locally ?
I was going to say since I see that you are in NJ, I have a couple of places that I deal with.
Well here she is
Fuel rebel 20x9+1
Nitro ridge grapplers 35x11.5 20
Mopar 2 inch kit with spacers installed
Orp front springs
Also installed the amp research boards
I’m very happy with the look
Yes ride is slightly more “ bouncy” but very nice still .. just different which is to be expected .
Well here she is
Fuel rebel 20x9+1
Orp front springs
^^^. When you say “ more bouncy “ when exactly does this occur ?
You can feel the road more for sure... and the truck reacts to bumps more than stock ... still rides great .... I’m assuming it’s more due to the 35’s ??
Since I’ve never owned a set of 35” tires sadly I am of no help there.
The 35's are a probably E rated, so they are heavy and sturdy which should translate the road into your ride more.
Plus your coils are now different, the ORG coils are supposed to be a bit more stiff.
So too many variables to narrow it down, but as long as you are happy.
With mine the tires made the biggest difference in feel and handling. I test drove my with the stock wheels and tires after installing the Mopar lift and it felt pretty much the same. Although I reused my stock coils, I did not install the ORP coils like you did. I did also add the Hellwig rear sway bar which I highly recommend.
I assume the sway bar helps control the body roll on corners. I do feel that it may be a bit too loose at times.
It still has a great ride !!
You gotta expect a bit of feel change when ur changing stuff around ... def worth how good it looks !!
