Justin.Chavez
- Jan 8, 2020
Great, thanks guys! Excited for the install, i'll post pics once complete.
How much Installed for package? I assume dealer installed?Had my Mopar 2” lift kit installed this week. Also installed 33x12.5r22 AMP MT tires. Pictures don’t do it justice. Looks way better in person and even more than 2”.
I haven’t installed this kit yet but I know the answer from other work I’ve done. You need to raise the truck high enough to remove the wheels.For those that have installed the kit yourselves, how high do you need to get the truck off the ground on jack stands to be able to do the install?
You'll either need to still add a spacer to the front or do not install the spacer from the kit in the rear.okay im also thinking about doing this, so i have a2019 ORG ram, if i use the mopar 2 inch lift kit, would i be close to level? i dont want the rake . and how does it ride compared to stock/ or are there any other options that will give me the same results without sacrficing the ride ? thanks . i`ve owned many trucks before but i have never donea lift or level.
Doesn't the new updated mopar lift kit address this issue? I know if you had the older version.there was a tab to correct the rake .You'll either need to still add a spacer to the front or do not install the spacer from the kit in the rear.
Go back through the discussion, there are a few people in here that address it.Doesn't the new updated mopar lift kit address this issue? I know if you had the older version.there was a tab to correct the rake .
So did they end up charging you?Hello All,
Wanted to create a thread for pictures/discussions about the updated Mopar Lift/Level Kit (Part#: 77072424AB) - available early May for the public.
I luckily was one of the first to receive and can verify that it does sit closer to level than the original Mopar-Fox 2" Lift kits.
(Comparing another Ram side by side with the original 2" Mopar lift)
I will compile some side pictures and get measurements on Monday and post them Tuesday, as there are about 4 posts going around discussing this update.
IF YOU ALREADY OWN A MOPAR 2" KIT - please be advised there is a TSB That will allow you to drop off your Ram should you want the additional 1" in the front.
(I believe is free of charge but will confirm for those when I drop off my truck Monday for a detail)
Hope this thread helps, lets discuss!
Just wanted to thank you! I purchased my left in Sept. Of last year and nobody mentioned anything about the spacer. I've been disappointed with the lift but didn't know I had any options. After about 3 hrs of text messages and emails today I finnaly got an answer. My local dealer will be ordering the spacer and fixing the issue. The rake on my truck is bad. Your truck looks great!Hello All,
Hello All,
