I’ve seen some posts in here stating the trucks are pre wired for the sub but don’t quote me on that. I guess the sub would mount behind the back seat, there should already be a space for it. As far as the amp I think it would work. You’d just have to do some more research. Maybe somebody has already done that or looked it to that set up and has some more info for you.
Hello,
I wanted to add a quick post regarding my experience in case it would help anyone else. I ordered 4 Kicker 46CSC6934 for the doors which came with the Metra 71-050 Speaker Wiring Adapters and installed them 2 weeks ago. Install was easy all except for the passenger front door speaker window got caught on the wiring and pulled out a connector. Otherwise everything fit perfectly. The sound quality is better but I do not feel like there is more bass response. I'll probably be looking to install a sub soon.
I noticed that all speakers appear to be installed with inverse polarity when using the polarity checker app on my android (negative shows on screen) both before the speaker install and after the install. There was no need to swap any pins in the connector when keeping the same polarity as factory. I find it odd that all the speakers are inverse but maybe that has something to do with playing nice with the ANC.
I have not noticed any issues with ANC after the install and it almost seems like there is less ANC in the cabin. I've noticed that I hear more road noise and more from the engine/exhaust which I like. Occasionally, before the install, I would have the loud droning noise that everyone complains about and I agree that it sounds terrible. Sounds like you are driving over the rumble groves on the highway that keep drivers awake. After the install I have not heard any issues with the ANC. This seems to make sense as the new speakers are a higher Ohm, you need more volume to drive the same response. I believe the ANC power is fixed so there is less ANC response on the newer speakers.
I'm getting new kicker 46CSC354 dash speakers today and will update after the install.
Thanks to everyone in this thread that has helped so far, your assistance is greatly appreciated.
