Lit_AF
Hardware Geek - Pro Detailer
Post pics guys, stop teasing us.-snip-
		Retrax ProAnyone have recommendations for a winter weather full truck cover?
I need this ^
				Gorgeous truck. Are the wheels powder coated?Next phase of modification complete. I got all the bronze wrapped with 55% tinted gloss vinyl to bring the bronze brightness down some, and reduce the clash with the body color. I also had the RAM emblems on the doors removed and had them put black in the recessed limited lettering in the door trim.
Next up,
- Powder coat the tow hooks either black like the wheels or color-matched with the tinted bronze. I don't want to leave them vinyl wrapped because they will get torn up if I actually hook anything to them.
 - Brake calipers painted to match the tinted bronze
 - Paint the chrome portions of the grille inserts gloss black
Thank you! I'm almost done with the transformation. Yes. they are the stock 22's powder-coated wet black with multicolor flake. Work was done by https://www.facebook.com/paintandpowderpros/Gorgeous truck. Are the wheels powder coated?
Side shot of the wheels?Thank you! I'm almost done with the transformation. Yes. they are the stock 22's powder-coated wet black with multicolor flake. Work was done by https://www.facebook.com/paintandpowderpros/
not sure if these posts helpSide shot of the wheels?
Thanks for posting, do you have pics from farther away at a couple of angles, so I can see how they look on the truck as a whole? With my spacers and larger tires, I am getting a lot of dirt splashed up on the truck (yes I know, I created the problem) but am concerned how the mudflaps will affect the ascetic of my truck. thanks!Installed my husky mud flaps. Such a better design than the MOPAR ones. Those are in the trash; where they belong. Install on the husky flaps is simple, throw the PPF on, peel the tape off the flap, bolt in using oem fasteners and then drill a hole through the flap and wheel liner for the last bolt and clip. View attachment 40339
What are you looking for as far as angles? From the rear of the truck and front? I can take as many photos as you want. These flaps do seem to stick further out than the mopar ones.Thanks for posting, do you have pics from farther away at a couple of angles, so I can see how they look on the truck as a whole? With my spacers and larger tires, I am getting a lot of dirt splashed up on the truck (yes I know, I created the problem) but am concerned how the mudflaps will affect the ascetic of my truck. thanks!
either or both, just wanted to see the whole truck so I can how they look on the truck from farther away. thanks, I appreciate itWhat are you looking for as far as angles? From the rear of the truck and front? I can take as many photos as you want. These flaps do seem to stick further out than the mopar ones.
Will do. If i dont get to it today or tomorrow ill take some after i wash it on saturday.either or both, just wanted to see the whole truck so I can how they look on the truck from farther away. thanks, I appreciate it
	Thanks! Those look pretty good. Very nice looking truck BTW.. Thanks again for replyingI have them on my truck as well. Here are some pics.![]()
