Figured I'd make an Official Thread for our Integrated Winch Mount Kit for the 5th Gen 1500's. In my opinion one of the most functional upgrades you can bolt on your RAM truck. Be prepared whenever and wherever you are.
Building on what I learned designing our very popular 4th Gen Rebel Winch kits, this kit has so many handy features that make it fit and function like factory. Even better - its available for all new body style 1500's!
Above: 2019 RAM 1500 DT SPORT with a Smittybilt X20 12,000lbs Winch with a Clutch Relocation Kit, and our Sensor Grill Insert Plate
My favorite addition to the Integrated Winch Mount is the Clutch Relocation Kit. Accessing the clutch control on your hidden Smittybilt or Warn Winch has never been easier! With this kit, the winch's clutch handle is positioned directly beside the fairlead giving you rapid and safe access to the engage or disengage the clutch. this is currently available for the Warn VR EVO and Smittybilt X20 Winches.
Above: 2019 RAM REBEL with a Smittybilt X20 12,000lbs Winch with a Clutch Relocation Kit, and our dual 8" LED Light Kit
Another NEW component included in the kit is the Hook Anchor. No longer worry about rattles and scratching the paint on your bumper by letting your winch hook dangle and flap around. Simply slid the hook over the securely mounted Anchor, and tension the line. Securely mounted, and easily accessed.
Above: 2019 RAM REBEL with a Smittybilt X20 12,000lbs Winch with a Clutch Relocation Kit, and our Sensor Grill Insert Plate
There are three options for Grill Inserts. Each made from stainless steel and powdercoated black to match the bumper.
2019 RAM Rebel - https://www.vicedesign.ca/collectio...ts/ram-rebel-2019-2020-integrated-winch-mount
2019 RAM 1500 DT - https://www.vicedesign.ca/collectio...ducts/ram-1500-dt-2019-2020-hidden-winch-moun
You can also check out my shop and behind the scenes action if you're on the gram @vice.design
Post up your 5th Gen with our Winch Kit, post Tips and Tricks you found when installing yours, and ask Questions. Ill do my best to answer them.
-Quinton
- LED Light Kit - Cleanly position two 8” SD Single Row Light-bars , each packing 3000 lumens, beside your winch fairlead. Also included is a complete pre-wired harness with switch.
- Sensor Version - Retain the use of your factory front parking sensors!
- Blank - For those who don’t require the additional lights, or parking sensors.
-Quinton
