FastBlackRam
- Aug 26, 2019
Everyone may already know this, but here's the science: "Exterior window condensation is simply dew and occurs when the window is colder than the dew point." So in the summer with high humidity and high dew points in the morning, you are going to get condensation (dew) on the windshield if the glass temp is lower than the dew point. So the cold air conditioned air escaping from the defroster vent will almost always cool the glass lower than the dew point and voila, condensation. In the winter, when you are heating the glass, no condensation on the outside. This will never be the case. The side windows in the summer fogging up on the outside? This happens if you have the side vent pointed too much, or sometimes even at all depending on the vent spread, at the window. This happens in every late model vehicle on the planet. Even a $250,000 supercar.
I feel like contrary to popular belief, the engineers may have designed it so a very small amount of air is routed to the defroster all the time to combat INSIDE condensation situations. If most of your windshield is fogging on the outside on a regular basis, your truck is the exception, not the rule, and you have a legit complaint if that much air is coming out of the defroster to cool the entire windshield below the dew point.
I am not saying this isnt a problem, just that not all of them are fogging to the point of blinding the driver. Mine is very minor, not across the whole vent and less than 2 inches max height and only in the early morning. I live in central florida so I see humidity and dew points that cause this condition from May thru October.
Some of you may say I am full of it, that's OK, I can take it. I can say if my windshield was fogging like some of your pics, I would be screaming safety issue also.
I also have to say my AC is ice freakin cold, seems like some are experiencing bad AC performance.
