vinnie45acp
- Feb 8, 2019
Anyone have a divider they want to sell?
What is the difference between the two divider part numbers? 68027414AE and 68027414ADAnd the part number for the divider is 68027145AE ?
I ordered and installed this unit , https://www.carid.com/amp-research/...n5v5Pa3d5Z498A8D-47wYfWYYkqgeltxoCycoQAvD_BwE , on my longhorn. most sites will highlight that , "this does not fit your 2019 ram" , but thats nonsense, install took me 20min. I am not a fan of the mopar sport version because it makes for less room. The one feature I do miss that my 2014 ford f-150 had was the bed extender was collapsible and would fold out of site.Maybe that is why they are curved? The curve is enough of an angle to slide past the regulation? I'm not sure what the viewing angle is. Most of aftermarket ones have a large curve compared to the box divider.
What are the part numbers. I keep seeing everyone ask, but have yet to see the part number. Do you still know it?I just ordered the pegs from my dealer. According to the parts guy they should arrive in about 10 days, while he was looking at the screen he said they're about to come off backorder.
I’m not sure.What is the difference between the two divider part numbers? 68027414AE and 68027414AD
I used the ALLEN wrench with know problem, just go slow.You’ll also need T-40 torx wrench. You could get away with a 1/4 Allen wrench but it’s hard to get completely tightened without stripping the bolt
It locks it down when used as a divider only. When used as an extender it has no purpose. Mine was keyed the same as my Ram from the factory, if not you will have two different keys if you got it after you took delivery of your Ram.I’m wondering how that would work based off of where the key is. It doesn’t lock anything in if it slides into the channels on the bed.
The cargo divider for Rambox has two wings that flip out to form the cargo extender. Ram no longer provides the mounting studs but the 2018 Ram studs can be ordered and easily installed. They work great.What are the numbers for getting the cargo bed divider for the new RamBox bed. Also is there a bed extender that you flips in and out of the bed to the tail gate? Had a Ford that did that. Also have a 5’ 7” bed.
68027414AE is the part number for the bed extender/cargo divider itselfWhat are the numbers for getting the cargo bed divider for the new RamBox bed. Also is there a bed extender that you flips in and out of the bed to the tail gate? Had a Ford that did that. Also have a 5’ 7” bed.
I just did this today and it was a T-50 not a T-40. You could probably make a T-40 work but it is a little loose and you could round it out.You’ll also need T-40 torx wrench. You could get away with a 1/4 Allen wrench but it’s hard to get completely tightened without stripping the bolt
Old thread...but I saw the problem today.
The parts run $85:
