dutchman187
- May 10, 2018
My guess is that the extender is not illegal in terms of, if you use one or not. Only in terms that the manufacturer has rules and regulations THEY must go by for producing and selling a car. The new regs mist have been implemented for this model year.
There should be nothing stopping you from ordering a part like any other part and installing it. If DOT were to inspect your vehicle, as in commercial types, then MaYBE theyd order you take it off. But state by state, I am quite positive it would never be an issue.
Manufacturers are simply not allowed to sell them as a factory on an OEM vehicle.
As far as them "taking it back", I also highly doubt they are confiscating them, unless someone had one taken away by a dealer (in which case the dealer was probably wrong). I suspect more likely they will dismantle it, consider their job done, and you leave with all parts in the bed.
You put it on at home.
This is closer to my take on it as well. My guess is they can't add it on for you from the factory if it immediately makes it in violation of the federal law. However, if you add it on, I think there are ways to comply with the federal law or at least make it so it would never cause an officer to bat an eye. For example, the reflective tape and especially trailer light kit being added should make the headlight obstruction issue moot.
