BeauxXL1200
- Jan 12, 2019
Thanks. So far, so good.That looks great!
Just had the Nitto Ridge Grappler 285/60/r20s installed. Liking them so far. A slight rub against a piece of plastic wheel liner in the front, but only in reverse and when doing a full lock turn. Not a big deal. A few pics.
Well, I haven't looked to see how much clearance there is between the tires and the UCAs. I'm assuming it's sufficient because the only issue is the slight rubbing against a piece of the plastic wheel liner during full lock turns in reverse. My 4x4 truck is neither leveled or lifted.How much space do you have between the tire and the UCA With those? You’re running stock rims, right?
I don't have a photo yet and sorry this took so long to post. I got a set of KO2 285/65/20 on and I have a stock set up at this point. I do not have any rubbing in Aero, Normal, Off-Road One, Off-Road Two. When I'm in Entry/Exit Mode I don't have rubbing when the tires are straight or partially turned. I never drive in this mode so I'm not too concerned but I will say it is close in this mode. I am considering doing a 2" level or 1/4"-1/2" spacer or different wheels with an more aggressive offset (current stock wheel offset is +19). For now, I don't have any rubbing at all in any mode I drive in. I also did a Hypertech Speedo Calibration.
THe 285/60R20 ridge grapplers are 33.7" in diameter and 11.5" wide. I run 305/55R20 nitto ridge grapplers on my stock suspension longhorn (no ORP) which are 33.23 diameter - 12.44" wide tires & my wheels are +18 and like BeauXL1200 only experience slight rubbing when reversing with full crank of steering wheelWell, I haven't looked to see how much clearance there is between the tires and the UCAs. I'm assuming it's sufficient because the only issue is the slight rubbing against a piece of the plastic wheel liner during full lock turns in reverse. My 4x4 truck is neither leveled or lifted.
And yes, the Grapplers are on stock Longhorn 20" inch rims. I think they look good on those wheels. Hope this info helps you.
SP97 are you able to post pictures of your truck in normal and Offroad Two? Just got my truck lifted with the 2” Mopar lift kit it’s probably pretty comparable.
Post Pics of yours too!
Is your truck leveled or lifted?Just had the Nitto Ridge Grappler 285/60/r20s installed. Liking them so far. A slight rub against a piece of plastic wheel liner in the front, but only in reverse and when doing a full lock turn. Not a big deal. A few pics.
SP97 Can you please post pictures? These are the exact tires I am looking at and want to make sure they fit well! Thanks!I don't have a photo yet and sorry this took so long to post. I got a set of KO2 285/65/20 on and I have a stock set up at this point. I do not have any rubbing in Aero, Normal, Off-Road One, Off-Road Two. When I'm in Entry/Exit Mode I don't have rubbing when the tires are straight or partially turned. I never drive in this mode so I'm not too concerned but I will say it is close in this mode. I am considering doing a 2" level or 1/4"-1/2" spacer or different wheels with an more aggressive offset (current stock wheel offset is +19). For now, I don't have any rubbing at all in any mode I drive in. I also did a Hypertech Speedo Calibration.
I have Nitto Ridge Grappler 285/60s on my stock Longhorn 20" wheels and the only rubbing I get is on a full lock turn in reverse. But I know the 285/65s are about an inch taller than the 285/60s. But you do have an inch of lift over my stock height Longhorn. They might work on your truck without any rubbing and without lifting it higher. Let us know what you find out.Hoping for some thoughts and advice. I have a Laramie with off road group so already 1" lifted. Wanting to use 285/65/20 with the factory wheels.
Will these tires work with this setup as is? Or should I add the Mopar 2" lift, which in my case would net an additional 1".
Also, no air suspension.
Thanks.
Thanks.
Thank you Combee1, I cannot tell you how long I've looked to see how this would look. That's exactly what I'm getting (level and tires) and I am glad because I love the look. Your truck looks very nice. Did you get the 2" ReadyLift with UCA's? That's what I'm looking at. Just got quoted for leveling kit, labor and alignment for $825.View attachment 35630
These are 285/65/20 Ridge Grapplers on stock 20s. I had a 2” level put on at the same time. Notice I have the ORG as well.
I get tire rub at full turn in reverse only. The rub is from the front of the wheel well liner, and can be easily corrected by tacking the liner. My “guess” after getting in there and looking, is that you could run these tires on the ORG without the level, but it would look “tight”.
Prior to the level, I measured front and back clearance from wheel center. Front was only 21.5” (at most) and rear was over 24”, so nearly a 3” rake. Your measurements may be different.
Hope that is helpful.
I have them as well and agree with Webbd30 word-for-word. I have about 60K miles on my ridge grapplers and I'm still riding like a rock star!They handle like my sports car.
They hug the road tight, and move like a car would.
No complaints from my end best tire I’ve run.
Bay Area, California- 2019 RAM 1500 Laramie Crew 4x4, 5'7 Bed, Granite Chrystal, E locker, Black Interior, 5.7 Hemi, 3.92 axle, Level 2 Equip Group, 12in NAV, Advanced Safety Group, Pano Sun Roof, Bed Utility Group, Air suspension, Off Road Group, 20X9 +1 Fuel wheels, 275/65R20 Nitto Ridge Grapplers, Deployable bed step, 33 gallon tank, Ram Box, Trailer break control, Mopar Slush Mats.
How close are they to your upper control arm? I felt behind my rim and bought 285/65-20’s and it doesn’t seem like much room back there for the bigger tire. I’m doing a 2” MotoFab level as well. No ORGView attachment 35630
