I saw a video with a guy that ran 2 catch cans to compare and determine if one was better than the other ( RX Performance Vs. Moroso). The $53 ebay had a plastic baffle in the top filled with aluminum shavings. I really didn't like the design, then saw this $19 Tasan on amazon that had a design like the Mishimoto. So for $19 I wanted to see if one would catch more that the other. My findings, after 700 miles there was about an ounce in the ebay can and nothing in the Tasan can.
@inlo ...I am looking more closely at your pictures and, maybe it's the angle, but the PCV should feed the INLET on can #1, the OUTLET on can #1 should feed the INLET on can #2 and the OUTLET on can #2 should feed the intake. I only see two hoses in your pics???
You are correct, I did connect the first can output directly into the input of the second can.@inlo ...I am looking more closely at your pictures and, maybe it's the angle, but the PCV should feed the INLET on can #1, the OUTLET on can #1 should feed the INLET on can #2 and the OUTLET on can #2 should feed the intake. I only see two hoses in your pics???
I would just get rid of the plastic baffled can and go with a Mishimoto or the "fake" Chinese one you already have.
I'd remove the problem rather than 'double down'.
Our engine is not a DI engine so there is really no rush to put an occ on our vehicles. So I assume they are still showing out of stock on their site? Have you reached out to Steve to inquire? I know some have used a billet one for around $75-$100 or less and I am sure it’s adequate but it’s no Mishimoto!So since Mishimoto can't seem to ever make more of their catch cans to sell, what alternatives are the best if one can't wait for Mishimoto?
I called them and told them which card I was putting it on and they put in my records and called me 2 weeks later and told me to go ahead and pay for it and they sent it right out to me.Our engine is not a DI engine so there is really no rush to put an occ on our vehicles. So I assume they are still showing out of stock on their site? Have you reached out to Steve to inquire? I know some have used a billet one for around $75-$100 or less and I am sure it’s adequate but it’s no Mishimoto!
How long ago was this?I called them and told them which card I was putting it on and they put in my records and called me 2 weeks later and told me to go ahead and pay for it and they sent it right out to me.
Been following this and I appreciate all the information. I understand the benefits. I wonder if the catch cans have any air pressure drop across the device that the PCV system wasn't designed for? (is there greater pressure drop when it's all gunked up?) I'm guessing it's negligible given the the amount of air flow passing by. Also, is there a fail safe with the Mishimoto such that if you forget to empty it there a bypass for the crankcase gas to still vent to the intake?
I wouldn't be concerned about pressure drop. No fail safes in these as they need to remain sealed for vacuum pressure. If you forget to empty it, based on the catch cans design, it will spill right back into the intake or can prevent the flow from PCV to intake from taking place. If you are going to install one, plan to check it religiously every 2-3K miles to be safe. The RAM can will hold at last 7oz I believe which is a TON of blowby. You will typically see about 1-2oz every 2-3K miles in the summer and that will increase in the winter based on condensation that can quickly fill the can with more water than anything else.
I’ll post a picture of my 54365 mile 2013 TB. Sometimes a photo is the BEST SELLER for something. At 54,000 miles my TB failed and was coated with grease on the backside of the butterfly.There's no need for one. If you want it get it but it wont hurt not having one. Its personal preference
I don't think the blow-by could cause that; the butterfly valve isn't in a position for the blow by to come anywhere near it by design (you can test this yourself by taking a vacuum, placing a water spray bottle between a hose attachment and the hose, placing your finger at the end of the attachment so you feel the air movement, then spray the water into the attachment towards your finger and see if the water is able to overcome the airflow to reach your finger).I’ll post a picture of my 54365 mile 2013 TB. Sometimes a photo is the BEST SELLER for something. At 54,000 miles my TB failed and was coated with grease on the backside of the butterfly.
Funny my oily crap was plastered on the “engine” side of the tb. Again this was on my 2013ram 1500 I traded in. Miss my 3.55 gears,lol.I don't think the blow-by could cause that; the butterfly valve isn't in a position for the blow by to come anywhere near it by design (you can test this yourself by taking a vacuum, placing a water spray bottle between a hose attachment and the hose, placing your finger at the end of the attachment so you feel the air movement, then spray the water into the attachment towards your finger and see if the water is able to overcome the airflow to reach your finger).
Sounds more like something somehow leaked into the throttle body, which eventually destroyed it; I don't think the Catch Can will hurt, but I don't think it will help either. At worst, the original issue was caused by something you may have done (like driving in an area saturated with oil in the air such as a refinery) and you never find out, so you assume the catch can solves your issue and continue driving in the same area which destroys a second TB. Still very unlikely, but I would investigate the TB issue more just in case and don't assume the blow by was the cause.
Edit: Further research may indicate the breather is before the TB on the RAM, which may lead to this issue. I haven't been able to determine if this is true on the DT's. I have also read that a damaged or worn out PCV valve will cause this issue; in this case, a Catch Can may save the TB, but it would not solve the issue as the broken PCV valve will lead to bigger problems if not addressed.
