No, it would reduce payload, by whatever the weight of the etorque system is (90ish lbs maybe).Am I understanding correctly that adding an e-torque to my 5.7 hemi 6'4" crew 1500 would give me an additional 300 lb of payload?
ETorque reduces payload by 80lbs, technically more if you opt for the 33gal fuel tank (eTorque std fuel tank is 23 vs 26 for non-eTorque)Am I understanding correctly that adding an e-torque to my 5.7 hemi 6'4" crew 1500 would give me an additional 300 lb of payload?
Thank you I made the mistake of looking at a dealership websiteNo, it would reduce payload, by whatever the weight of the etorque system is (90ish lbs maybe).
The Ram website is generic (not specific to the Laramie). In this case it lists the MAXIMUM payload for a 1500/crew/4x4/long bed, lowest trim and basically no options. Misleading isn’t it.Can someone enlighten me? My jamb sticker shows 300 pounds less payload than what's on Rams website for a Laramie. My only options to this trim are LSD, trailer brake control and navigation. I cant imagine those add an extra 300 lbs. What am I missing?![]()
Sent from my SM-G960U1 using Tapatalk
Well, that's dumb. Why even list the different trims on the payload page? Thanks for clearing that up. Sorry of it's been covered already.The Ram website is generic (not specific to the Laramie). In this case it lists the MAXIMUM payload for a 1500/crew/4x4/long bed, lowest trim and basically no options. Misleading isn’t it.
Yea, he’s an idiot. Ask him to run 3 different vins on the lot...
Truck details? (Fill out signature) how’s it compare to sticker?scaled truck is 5580lbs 1520 payload
the sticker is off by 300 lbs so im assuming the sticker includes 300 lbs for passengers ,oh I should also add the truck scaling included a full tank of fuelTruck details? (Fill out signature) how’s it compare to sticker?
I think that’s just the way it works for all the manufacturers. I’m researching a Limited trim CC 4x4 5.7 short bed. Towing chart says ~1800 pounds max payload but we know from the payload stickers we’ve seen that actual payload for this trim is ~1400-1500.
I’ve been looking at a Platinum F150 also. There its even more misleading. They claim max payload of 3000+ pounds (they don’t break it down as well as Ram does for each engine/cab/bed/driveline combination in their towing guide). Well the actual payload stickers for the Platinum trim are in the same range as the Ram ~1400-1500lbs.
The new gen Ram is more competitive in payload capacity than the previous generation, at least at the higher trim levels.
