@grinch72 You are a genius. Your explanation of how start/stop is interacting with the system is spot on. I tested it today and works as you’ve described.
With that said, I’m not a fan of this use model.
(Example; if you shut the vehicle of with tow mode on and come back the next day tow will engage. I’m no longer towing so I turn it off. Start/Stop engages and hence tow comes on again. Only way to stop is to pull over and shut truck off. (Or reboot Tazer while in motion-haven’t checked if you can do this)
It would be nice to have a menu option to turn on/off the feature.
