What is in the settings is to disable the INDICATOR on the dash only...not the feature itself. We all wish it was that easy![]()
Ahh got it
Your halos should be on 24/7. I’d go to the dealer if they aren’t. Something is wrong.hey Guys! Is there a setting in the Tazer for the halos to come on daytime? My halos do not come on during day time. I do not run any DTR at this point.
I already pitched that idea to him and he was gonna play around with it and see why he can do. Basically it would return to last setting kind of feature.Just had a brain fart:
What if Tazer DT sent a signal to enable Gear Limit every time the truck was shifted to drive? This would effectively turn off MCDS (4 cylender mode) that so many people hate. They would sell out overnight.
Z-Automotive...your welcome.
The issue is that you have to press + several times to get to 8. It starts incrementing/decrimenting from whatever the current gear is. It would need to happen immediately when going to drive and in first gear or it wouldn't be consistent. Hopefully they can make it work.I already pitched that idea to him and he was gonna play around with it and see why he can do. Basically it would return to last setting kind of feature.
I don't know if this helps but I would be fine with it. Can he wait until he sees the transmission in 8th gear then send "-" pulse one time.The issue is that you have to press + several times to get to 8. It starts incrementing/decrimenting from whatever the current gear is. It would need to happen immediately when going to drive and in first gear or it wouldn't be consistent. Hopefully they can make it work.
The 19 I turned back in for this 19 had the halos working at all times in any mode. This truck Halos only work when the head lights are on or park lights.....When you put in Auto mode halos go off and stay off until lights come on.Your halos should be on 24/7. I’d go to the dealer if they aren’t. Something is wrong.
That would work for ~45+ mph driving. Might not happen in town where MDS is on more often but you may not see 8th gear in slow traffic. Sending 7 (or 8) "+" immediately after engaging drive would be 100%....if possible. Who knows. Hopefully they can test it out.I don't know if this helps but I would be fine with it. Can he wait until he sees the transmission in 8th gear then send "-" pulse one time.
[...] I’d like to add a front camera if possible.[...]Is there any way of doing this?
I happened to text back and forth with ZAutomotive about this a few days ago - they sell a dual AV input harness for other UConnect systems but haven't confirmed it on the '19s - I'm buying a Tazer in the 2nd Group Buy just for the sake of this option if it becomes available in the future. fingers crossed! I'm actually bummed I didn't know about the 'tow package = 360 cam delete', otherwise I would've spec'd my rebel differently
I don’t have the tow mirrors but I also didn’t do the surround view so it didn’t matter. Just want that front cam somehow.
Yeah I only want to do it if I can hook up the OEM camera.I'm with you - all i have is backup - so this harness (link) is what i'm hoping will work with basically any wide angle camera added to the front. that said, the OEM front camera is embedded into the 'ram' logo beneath the 'A", that would be a trick install
Ok i reached out to everyone on here that was interested. Gonna wait till tomorrow for everyone to respond.
I dont see the need to have two TAZER forums going, so please post in the MAIN TAZER forum going forward:
TAZER DT for 2019 RAM 1500
What is in the settings is to disable the INDICATOR on the dash only...not the feature itself. We all wish it was that easy :( Ahh got it :) Sent from my iPhone using Tapatalk5thgenrams.com
Thanks ALL![]()
