Add 1” to Mopar 2” Lift
subaru79
Oceanside CA
Is this a new bulletin and are the spacers included? In regards to The warranty reference, does that mean warranty will pay to have the spacers put in?
Yes It will pay for it if
#1 - You have Proof of Purchase
#2 - Chrysler/ Jeep installed it
That is what I was told. I purchased from Chrysler Dealer but I had my Mechanic install it. So at this time my dealer is just providing the spacer for me...
PorBoy
Millville NJ
Oh that’s perfect as I purchased mine and had the dealer install it. I want to make sure that when they do this they do an alignment and make sure my headlights are also aligned.
wildh24
Awesome. Thanks. Do we know how much it raises the front? I'd kind of like a little rake, but not as much as there currently is.
subaru79
Oceanside CA
From the looks of it I would say 1/2" to 3/4" nothing super crazy.
The Mopar lift is 1.5" in Front and 2" in Rear making a 3-1/2" to 4" Rake Depending on Build.
I only did the lift in Font and Did NOT Install the Rear Spacer , Only Shocks . So my 2wd CC with 6' Bed and Tow Package has 1.5" Rake to it
jwiley386
Here is mine, it has the updated 2" Mopar Fox Shocks Lift/Level kit that releases in May. Was told I was one of the first in the nation to receive.
I will say, compared to another truck on the lot with the original Mopar 2", mine sits about an inch or so higher in the front and is noticeably more level but still have a slight rake, which I like.
22765 22766
PorBoy
Millville NJ
Darn I can NOT wait to have mine done as that look is what I am after but I’m not man enough to handle those 35” tires lol. FAE1E6A8-5E28-4197-93CE-FDA1A151960E.jpeg
skol
View attachment 22765 View attachment 22766
Which UCA’s are you using? I got the Mopar Lift Also. Just waiting my the extra component from Mopar to level it out. That truck looks awesome
ksn240
Any chance we could get a straight pic from the side? Have you measured yet to see how close to level it is? What do the CV angles look like up front? Looks good.
jwiley386
She goes in for a full detail on Monday. I will have some updated pictures for you all Tuesday, please also notate any questions you have so I can attempt to answer. Here is what I have so far,
- Have you measured yet to see how close to level it is?
- What do the CV angles look like up front?
- Which UCA’s are you using?
wildh24
Measure center hub to fender on both front and rear. Then we can tell calculate how much the new parts add on this lift.
jwiley386
Darn I can NOT wait to have mine done as that look is what I am after but I’m not man enough to handle those 35” tires lol. View attachment 22767
Don't fear the 35's! haha Mine drives very smooth, especially for being on Toyo MT's. Also I can't even hear the tires, which is strange but also nice.
Jamhav
Awesome. Thanks!
I’ve called my dealer and they have no idea what I’m talking about when I ask them about the updated struts. And why does it still say it’s a 2” lift when you look up that part number if it lifts the truck 3” in the front?
wildh24
Mine didn't either. I printed out the TSB and explained. Then they got it. They asked how I knew about all of this stuff, I told them I read a lot on this forum. Then another guy who was there too said the customers are usually the first to know as a result of forums like this.
jwiley386
...Assuming I measured this correctly, I also did it on the fly so I'm sure its close but may be off slightly:
- Front center hub to fender: 24"
- Rear center hub to fender: 25 1/2"
Honestly it is this perfect amount of rake as it sits almost level with hauling my boat and the right amount of nose down when not towing. I'm partial to a slight rake though.
23106
ksn240
Looks great! Much better than the original kit. I don't ever tow so I prefer the truly leveled look. You did not add the offroad package springs correct? Somebody was doing that and I couldn't remember who. It looks like coupling the updated Mopar kit with the offroad package would leave it almost perfectly leveled with ~1/2" of rake, which is unnoticeable and allows for a little added weight in the bed at times. This would essentially give you the 3.5" that the Readylift kit does but strictly with new struts/springs instead of spacers (except for the rear) giving a much better ride.
