MDBumblebee
- Nov 6, 2018
Quality is the same as any other I suppose. Weathertech has a good reputation. It clips between the under-hood rubber seal and the hood. You replace 6 OEM push pins with 6 they give you. Took about 30 mins.First one I e seen. How’s the quality? Was thinking about doing the AVS one. Does it clip on the hood at all or just attach underneath?
I preferred this type of installation over the 3M taped versions out there cause all kinds of dirt and grit gets sucked up inside of there if it's not completely sealed; I found that out after removing a spoiler from my Camaro.
