I installed my Lomax yesterday. Best hard folding tonneau ever IMO! I had spoken with the actual designer at Agri -Cover, which convinced me to buy. Super simple so that it is elegant in design! The matte textured black matches the bed rail caps so that the low profile cover just blends in. The way the seals wedge gives excellent sealing all the way around.
This morning I dropped my truck for PPF and ceramic coating so I will post pictures of the cover in a couple days, but the important point is that they took a soap cannon and 1200psi rinse gun to the truck as step one in prep. I popped the gate after they finished and the only sign of water was at the front corner of the bed, driver's side, which is where my spray in bedliner has the tonneau seal a little uneven. I have not had this kind of performance out of a tonneau since the 1-piece ARE lids I've had. Blows the doors off the BAK's I've had for look and performance! I won't miss the vertical fold against the window either. The Lomax is RIDICULOUSLY simple to pop off and pop back on and very lightweight. It sits perfectly on the crew cab rear floor if full removal is needed away from home.
Anyone looking at a hard folder, give the Lomax a look over! Luke delivers at excellent pricing and superior customer service too!
My only gripe is related to the packaging. It's better than most, but needs to be improved. My rails had powdercoat scratched off them because the rail attaching clamps came out of their non-sealing, plastic envelope and roamed all over the box! The rails were only wrapped together and not for protection. Had they been stretch wrapped 100%, there would have been no scratched finish. Had a ziploc been used, there would have been no scratched finish. The folded cover also needs to be in a padded sleeve. These are cheap things from U-line, and this customer would pay the extra $5 for! I am living with the scratches on the rails since they are aluminum and also because you don't see them unless the cover is folded open. In the nice weather, I'll touch them up to make them less noticeable.
