I think you'll get water in the back corners with a solid cover. Water gets in through the big gaps on each end of the tailgate. There are no seals.Valid points - and I do find myself being irritated whenever I have to find help with taking off the solid cover. My poor wife ...
Just a bit concerned about the numerous comments regarding leaks in the folding tops. Plus , during the winter when there’s ice and snow, how challenging is it to open the panels?
I’ve had a truxedo on my ‘08 since new. No issuesI’m looking into the Truxedo covers, a few of my buddies have them and swear by them.
I agree with you....I very much like the pro X15.....they did make an effort to "fix" the engineering problem with me but I ran out of patience as they wanted more and more info and measurements. …….I figure that was THIER job to get it right BEFORE selling it. I have made mine "work" but it s not water tight because of the misfit …...I am only using it until I can get the fiberglass cap I want.....sure hope the cap manufactures make sure that they fit before selling them!!
Don't know about question #1. I do not plan to walk on mine. As to question #2, I can release my tailgate with my remote while the cover remains closed. Luke was very easy to work with, and very quick to respond to my query, and even faster shipping to me. Highly recommend.After reading through all of the posts I'm leaning towards the Lomax. I have 2 questions.
1. It can hold 400 lbs of evenly distributed weight. Can I walk around on it to clean top of truck/skylight? I had an Extang back in the day and I could walk on it no problem.
2. Can you open (including remote lower) and close without lifting Lomax up?
Thanks!
www.retrax.com if you are interested in a retractable cover...best in the business! Mine looks AWESOME![]()
It was cold this weekend when I installed the Lomax, so I did not really look it over once I got it on. Coming from a Retrax on my last truck, I can tell you that I prefer this Lomax over the Retrax. With the exception of the occasional hang up where the Retrax would not roll up, I had no real complaints. I like to roll around with my Pano and rear window open most days. I did not like hearing the Retrax rattling around in the wind. The Lomax is quiet, very easy to operate, and even easier to install/remove. Just washed my truck, as it’s 40 here today. This is the only water I could find in the bed, and I think that dripped in when I lowered the tailgate.
Hey pal, would you mind telling us, exactly how much room the retrax takes up? I ordered the 6'4 bed because i do a lot of work out of mine hauling large equipment. The only thing holding me back is not knowing/seeing just how much room you lose in the bed. Also, did you get a good deal? I see the regular price is just over 1800. Thanks.
Reposition the tonneau, go to auto parts store and pick up some additional Weather strips, apply black silicon caulk to exposed gaps. Really depends on how much effort you put into it.
After I installed mine yesterday, I closed my self up inside the bed and I can see gaps at the outer edges where is meets the tailgate. Is this normal? How does one fix the gaps so it doesn’t leak? I also see a very small amount of light at the front where the top lays on the front wall of bed.
Why is the Paragon not getting the love the Lomax is? I'm leaning towards the Lomax but this looks very nice with a similar price point (Paragon is 20% off with code). Thoughts?I de-badged my Peragon cover today. Very quick and simple to do as there were only a couple of really sticky badges and a label. I like the look of no-advertisements and logos on the cover.
I wanted a non-black cover as I put stuff in the bed I'd rather not bake in the Texas heat. I figure white might help with the heat. I went with a color-matched Ivory Tri-coat Peregon cover as it met all my specs:
- solid aluminum and stainless steel hardware
- double dead-bolt
- locks with a key, not going to be opened with a coat hanger.
- no canister
- no lost bed space when I need all of it (folded cover removes/re-installs in about 30 seconds and stows in the back seat, bed, garage, etc)
- low-profile, sleek look
- fully opens/closes instantly
- color matched to the truck. Not into the generic black cover.
