Hammer1
I think its the pano roof. Nothing will be fixed
			 What about this idea, Ram Social Care?  They are fabulous trucks but.............. don't let lack of problem resolution become a reason to lose buyers.
     What about this idea, Ram Social Care?  They are fabulous trucks but.............. don't let lack of problem resolution become a reason to lose buyers.For the folks having the wind noise, what type of mirrors do you have? Standard or towing?
We recently had high winds in Southern CA and this was the only time I experienced loud howling from the windows closer to my tow mirrors. Other than that its been quiet. Like someone was blowing hard into a saxophone.
I have exactly the same noiseI’m getting an annoying road noise from the backside/ rear window area of the rear seats. I just had my brother drive me around while I sat in the back and **** noise is coming thru. Noise can be heard even a 10 mph. I used my phone to record the noise but dont know if anyone can tell a difference.
@NoRamForUconnect Where you getting this noise? I'll be placing some tape tomorrow to see if road noise is gone.
there is a very large vent behind the rear seats. if you take the rear carpet off you can see it. thats where the noise is coming from.I’m getting an annoying road noise from the backside/ rear window area of the rear seats. I just had my brother drive me around while I sat in the back and **** noise is coming thru. Noise can be heard even a 10 mph. I used my phone to record the noise but dont know if anyone can tell a difference.
Look down the gap between cab and box towards ground and see if you have the horizontal 4' rubber seal across bottom of opening. Apparently the trucks built after a certain date don't have this seal. It blocks the road noise from being heard through those vents. My Rebel built in July 18 has this rubber seal as well as the side gap vertical seals and is very quiet. Some members are ordering the seal and adding it. This topic is in earlier posts on cab noise threads also. Hope this helps. Some members had missing rear window sealer also.I found two vents in the rear cab. I noticed while putting some tape on the rear glass this morning. Taping rear window didn't help reduce road noise at all. I'll have to take the rear carpet later today to inspect the vents. Hoping for a missing part or something fixable. This road noise is annoying.
Where exactly is the rear window seal you mention?Look down the gap between cab and box towards ground and see if you have the horizontal 4' rubber seal across bottom of opening. Apparently the trucks built after a certain date don't have this seal. It blocks the road noise from being heard through those vents. My Rebel built in July 18 has this rubber seal as well as the side gap vertical seals and is very quiet. Some members are ordering the seal and adding it. This topic is in earlier posts on cab noise threads also. Hope this helps. Some members had missing rear window sealer also.
