yellowboy
I will not fix a truck under warranty no matter how well the fix works or easy the fix is !
I'll answer this by saying I am under an NDA in that regard.Did you do this? Is there nay documentation or case information you can share?
PM sent
Yes, that is the same sound mine makes.
Tea kettle wind noise problem fixed.
PLEASE look back at post #427 on 9/11/19. We were able to fix the problem!!!
Also post on this if it fixes your noise so others can see.
I picked up my 2020 Limited black appearance on friday, drove the 200km home and yep I have wind noise which seems like it is coming from the driver side a pillar area. I read this entire thread, lots of different noises and potential fixes. i have the noise regardless of recirulation is set too. only once i get up to say 70km/h.
any fixes I can try at home? i detest having the dealers work on my truck if possible.
My 2019 Limited with sunroof and tow mirrors has this exact same "howling" sound. (Thank you to everyone that captured it on video - I tried and failed) I mentioned it to my dealer and they said that they had never heard of it. With so many reports from owners, will there be a TSB issued for this? (Looking at you RamCares) I'm headed back into the dealership tomorrow for radio and rear brake updates. It will be interesting to see what they say to this noise now ..
Hi boomtastic,
As our team here is not mechanically trained, we are unable to speculate on this inquiry. However, please be sure to keep us updated on your dealer's findings. We are just a PM away if any additional support is needed while addressing this with your dealer.
Mark
RamCares
Appreciate the reply and explanation. I discussed the issue (and this board's findings) and the service writer was unaware of it. He did talk with his tech who acknowledged it was a "known issue that is being addressed", but they had no short term resolution. I requested that it be documented as I am nearing the end of my 3/36 warranty ...
If you document something that is an issue under warranty is it covered after the warranty expires ?
I have that exact issue with my 18 ram 1500, feels like the door is flexing, truck is a dealer now. Did you find a repair yet?anyone have wind noise from drivers side door up top by the corner. I can pull in with my hand and it goes away but if I lean just a tad on the door it has some serious wind noise.
I have a 2019 Lonestar and the wind whistle is so bad I almost can’t drive the truck. At 60+ mph it is louder than the radio sometimes. Tried the recirculating button but that did not help at all. Please someone help me fix this. Had a 2015 that was great with no issues at all. I did have both exterior mirrors replaced due to the motors going out on both of them.
