bang for buck I recommend the Smittybilt X20 Comp in either the 10,000 lb or 12,000 lb size. Most opt for the 12,000 lb version - it has a bit more power. General rule of thumb is 2.5 x vehicle weight. Of course with a snatch block you can get away with a smaller winch. This winch comes with a handy wireless controller that works nicely with this kit.
The VR 10s and 12s are also nice winches. They come prespooled with line, and the clutch actuator turns a little bit smoother when compared to the smitty. They have a waterproof and dust protection rating of IP67, while the smittybilt housing is rated more waterproof at IP68.
The ZEON 10s and 12s (PLATINUM) is a high end winch that comes with a wireless clutch, as well as a wireless in/out controller. It actually can even wire into and control your lights. All these features come with a heaftyier pricetag tho.
You can make any winch wireless with an aftermarket kit and a bit of wiring. After we get all these orders sent off we'll do a video that goes over that, and also how to wire a switch into your cab. We plan on releasing a wiring kit and a universal wireless controller.
Note: The Smittybilt X20 Comps do come with line, you just have to spool it on the winch after its installed on the vehicle. Essentially a small extra step.
Appreciate all your support and orders!
