U
User_3336
Guest
Not yet, sit on the lot several months before it was purchased.. Its a garage truck now.
Scram, I believe it have the same issue. Did your drip look like this? Also I have attached a photo of my third brake light gasket/seal after a rain.Between parking in a garage and the drought this year, there wasn't a lot of opportunities for leaks. First big storm this fall, and thanks to the paranoia induced from this site, I caught the leak immediately. One tiny drip in the corner, no stain thankfully due to a black headliner. Upon inspection of the gasket it was found to be soaked like a sponge.
21 BH Night Edition. Build date was 1/5/21. Picked up the truck on the 1/13/21. I added weather seal the first week. So far I have went through 2 car washes with no leaks. I know it's still too early to tell.
Looking at your first photograph the ribs that the lamp housing screws go into are different on yours than they are on my 2019. Also, mine does have any foil near the rear edge of the headliner.21 BH Night Edition. Build date was 1/5/21. Picked up the truck on the 1/13/21. I added weather seal the first week. So far I have went through 2 car washes with no leaks. I know it's still too early to tell.
Looks like third brake light to me, the wet headliner in the corner is a tell tail sign. I removed the old gasket with some elbow grease and goof off. I then applied the marine gasket from Lowes/Home Depot. Of course now I have another drip, but that's from around the frame which I'm sure is bound to crack sooner or laterScram, I believe it have the same issue. Did your drip look like this? Also I have attached a photo of my third brake light gasket/seal after a rain.
what did you do to resolve the problem and stop the leaking?
Well, you can see in the post above that I utilized Flex Tape over my CHMSL before getting my Leer topper installed. I was relatively certain that if it could keep sharks out of a boat made from that crap that it would keep water out of my Ram - WRONG! I installed it back in January and this morning when I got into my truck I got that same feeling many get when they look in the rear view mirror to see their rear window leaking like a sieve. I climbed up this afternoon with a step ladder (remember the topper is on so I have to get to it from the top) and saw where the Flex Tape failed in a number of places and was letting water into the CHMSL. I just spent the last hour "rubbing" that crap off and will now make an appointment to get it inspected/replaced or ??? The good news is it only was dripping from the top of the frame and did not get my headliner wet/stained.Woke up during the night to hear it raining hard. Has been raining all morning and will continue until this evening. My CHMSL has never leaked but wanted to ensure it doesn’t develop into a problem as the gasket goes through free/thaw cycles and degrades over time. $12.50 for the Flex Tape was cheap insurance. No more worries.
And the beauty is I have enough for another application...if I ever need to record the CHMSL.
So after reading the thread, do you think it was the antenna mount or don't know yet? Their next search includes that and the sunroof drain which my service manager says go through the back of the cab where the leak is -- could be a connection possiblycheck out my thread "rear window leaking" all of this sounds familiar.
Mine’s garage-kept, but I do run through car washes pretty regularly. I’ve also removed the CHMSL a couple of times to install LEDs. Knock on wood, no signs of leakage.My 2019 5th gen doesn't leak at all. It's parked outside and I use an automatic car wash weekly since it was new.
It was the antenna mount. We had 3 inches of rain here from the tropical storm Thursday, no leak. I do not have a sunroof.So after reading the thread, do you think it was the antenna mount or don't know yet? Their next search includes that and the sunroof drain which my service manager says go through the back of the cab where the leak is -- could be a connection possibly
Thanks for the info. Mine is leaking in the same area and hopefully it's the antenna and not the sunroof drain. The manager said they have to take out the entire headliner if it's the drain.By the way ---I had water running down rear window,dripping near the speaker and near where it says "airbag" so where you find it is no indication where it's coming in.
