Richard320
- Aug 3, 2019
I refuse to answer. I do not want to jinx things.
Although I’ve never had any leaks, I’ve thought about using FlexSeal as added protection before installing my new Leer canopy. Mind if I ask if you used FlexSeal spray, liquid or ? to do the job?no leaks, but when I swapped out my bulbs for led, I did some "Flex Seal" around the opening for added insurance.
My LEER canopy/topper will be in next week so I wanted to get ready to ensure no potential CHMSL issues after it is installed. I picked up some 4” clear Flex Tape which is the perfect size to seal from the bottom of the brake light to just before the satellite antenna. Works perfect and appears I shouldn’t have any issues for a few years.Although I’ve never had any leaks, I’ve thought about using FlexSeal as added protection before installing my new Leer canopy. Mind if I ask if you used FlexSeal spray, liquid or ? to do the job?
Woke up during the night to hear it raining hard. Has been raining all morning and will continue until this evening. My CHMSL has never leaked but wanted to ensure it doesn’t develop into a problem as the gasket goes through free/thaw cycles and degrades over time. $12.50 for the Flex Tape was cheap insurance. No more worries.My LEER canopy/topper will be in next week so I wanted to get ready to ensure no potential CHMSL issues after it is installed. I picked up some 4” clear Flex Tape which is the perfect size to seal from the bottom of the brake light to just before the satellite antenna. Works perfect and appears I shouldn’t have any issues for a few years.
If you decide to do it, start by applying the Flex Tape at the bottom of the light. Make sure you’ve got 1/8” to 1/4” of the tip hanging below the bottom of the light as you’ll use this to roll it under the lens after you’ve worked any bubbles out that have to go down instead of up. Now start pressing it on by rolling up with your hand. I started 3” over to the left of the light and applied it along the bottom edge of the fixture until I was 3” over to the right pay the light. Then start applying it rolling with your hand from top to bottom. Get all bubbles out, finish by rolling the bottom ends under the light and you’re done.
Also, I tested it on the inside of my bed to see how removable it will be if I need to replace it or change a bulb. I stuck it on and left it on over two nights. This afternoon it peeled off after spraying it with orange citrus sticker remover, letting it sit for five minutes and thepeeling on a leading edge. Also, it doesn’t degrade the brightness of the LEDs so should be fine...time will tell.
View attachment 79047View attachment 79048View attachment 79049
Had my 2019 for 2 years and NEVER a single drip. Build date was December 2018.
