Caballonegro
- May 20, 2019
No above our K&N air filter !White fabric?
There was nothing between the speaker and the plastic cover.
Can you post a pic of your installed holster? I've been trying to figure out a configuration- thxInstalled an AlienGear Level 2 retention holster and put “gym floor” tiles in the bed. Two tiles wide is perfect but the 5’7’ bed is a few inches short of three tiles deep. A single straight cut It is ust right for a RAMbox bed. Lock’er Down should arrive today!
Tail gate seal?? Why?
These should give you the idea. Right hand holster with attachment point moved to other side.
View attachment 31511View attachment 31512View attachment 31513
Why remove it? Just curious, I read a few threads and it seems that removing it does not make much difference. I am good either way, just hoping to understand the reasoning.No above our K&N air filter !
LED reverse and CMHSL
Where did you get those LEDs. Been wanting to change mine over....only stupid incandescant bulbs on my limited
I see that you included it above; sorry
what color is your truck
new wheels 20x10 -25 on 34.6x11.5x20 (bridgestone ko2 285/65/20)
Direct fit with the metra wiring harness, you cannot get the polarity wrong as the wires only fit one way. Pop the cover, use a 7mm socket to remove two screws, replace-tighten-push the cover back on. 15min per speaker tops. It is a tight fit if you have big hands, otherwise a simple job.
