Installed an AlienGear Level 2 retention holster and put “gym floor” tiles in the bed. Two tiles wide is perfect but the 5’7’ bed is a few inches short of three tiles deep. A single straight cut It is ust right for a RAMbox bed. Lock’er Down should arrive today!
Can you post a pic of your installed holster? I've been trying to figure out a configuration- thx
Tail gate seal?? Why?
To keep the bed dry when driving in rain and dust out when I take a dirt road. I used the TruxSeal but would not recommend it. It's little too think for bottom of tailgate and not the best profile for this model truck. Good quality just not best application.
No above our K&N air filter !
Why remove it? Just curious, I read a few threads and it seems that removing it does not make much difference. I am good either way, just hoping to understand the reasoning.
well if don't think it makes a difference, you should leave it. I was going to take mine off but decided to do the S&B CAI instead.
LED reverse and CMHSL
Where did you get those LEDs. Been wanting to change mine over....only stupid incandescant bulbs on my limited
I just ordered LED lights for the third brake light and cargo lights. Whole truck is LED but that? Makes a ton of sense! But then again it might be the cheapest mod I have done to date so I am not complaining.
I purchased them off Amazon
JDM ASTAR Extremely Bright 2000 Lumens 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup Reverse Lights, Xenon White https://www.amazon.com/dp/B01GGK6QDW/ref=cm_sw_r_cp_api_i_b9znDbZ10HMPJ
Antline Extremely Bright 921 906 W16W 912 T15 24-SMD 3030 Chipsets 1600 Lumens LED Bulb Replacement Brillant Red for Car Center High Mount Stop Third/3rd Brake Lights (Pack of 2) https://www.amazon.com/dp/B07NMB961T/ref=cm_sw_r_cp_api_i_XdAnDb52ASY2A
new wheels 20x10 -25 on 34.6x11.5x20 (bridgestone ko2 285/65/20)
Guys I finally moved from 2'' spacers to 3'' spacers. What I had before were the Yitamotor spacers and went to Bora Spacers, only because Bora makes them in a 3'' and higher. I do get a little rubbing but i'll heat gun that in the wheel well to make space. Here are some pics!! 31571315723157331574315753157631577315793158131582
Hey, those AVS headlight and tail light covers look really nice. Do you have any up-close pics of those?
Do you know if they make them to fit the LED headlights and the LED tail lights that are part of the Advanced Security Group? I did some searching and couldn't see where they have anything except for the trucks with halogen lights.
That i do not know tbh, from what i see the mold is specifically for the LED tails the headlights are made for both. but i made them work with no issues. have had them on for 4 months now through car washes, highway speeds etc.
ill get some up close shots soon
Direct fit with the metra wiring harness, you cannot get the polarity wrong as the wires only fit one way. Pop the cover, use a 7mm socket to remove two screws, replace-tighten-push the cover back on. 15min per speaker tops. It is a tight fit if you have big hands, otherwise a simple job.
Do you know the exact part number for the metro wiring harness? And did u replace the speakers from an H&k system or the Alpine?
I have the H&K and I’m not overly impressed for the amount of money the upgrade was...
