swizlstik
Here we go again…..
It's strange, I am also in the Phoenix area and have never had a problem with my USB or AAWireless in the heat.Same here… starting to fail again. Phoenix sun is brutal.
No issues for me so far either.It's strange, I am also in the Phoenix area and have never had a problem with my USB or AAWireless in the heat.
Hi Richx1,
We received your PM and hope to hear back to assist you further!
Steph
Ram Cares
@Jimmy07 i want to revisit this. It seems the new revision of the usb hub doesn’t fix this, is this still the case?The media hub itself is supplied constant battery power via fuse F43, so it will charge devices full time (which it does for me).
The usb cable that links the media hub to the radio will stop receiving its 5v supply once the radio goes full asleep, and that would stop any type of data transfer from device to radio.
Ram should be thanking those who tinker with their trucks for themI verified that resetting fuse F43 does fix the issue after you drive a a bit and let the cab cool down. There’s just no easy was to do this while driving.
Also, I have a buddy at work with a 2021 ram. His outside temp showed 124, and his usb ports were still working. Mine did not yet again, so I reached out to @RamCares to inquire if there is a way to tell which version of the usb hub was installed by the VIN so we could compare part numbers without taking the center console out. Haven’t heard back yet.
I went ahead and ordered the 68272254AE version. I would guess that’s what the 2021 would have in it.
Why would they thank people? It's not a "fix" for the problem. It doesn't help Ram/Stellantis in any way. I guess other than maybe appeasing some enough that they stop bitching about the issue to make them fix it properly.Ram should be thanking those who tinker with their trucks for them
I dont care to be thanked. I just want it to work.Why would they thank people? It's not a "fix" for the problem. It doesn't help Ram/Stellantis in any way. I guess other than maybe appeasing some enough that they stop bitching about the issue to make them fix it properly.
